What's easier to use? Ph expansion or....
Posted: Tue Jun 23, 2015 2:40 pm
by skehole
A separate ph controller to monitor ph in a calcium reactor. This reactor will be regulated with a carbon doser reg and fed with a cole Palmer masterflex pump. So, the probe will only be monitoring ph and cutting off gas only if it gets too low. Anyone have experience in this dept???
Sean
Re: What's easier to use? Ph expansion or....
Posted: Tue Jun 23, 2015 3:20 pm
Or what? We have a built in function to turn on and off the co2 regulator if ph gets lower than you want. I think it's better to have the ph expansion, but the primary ph would work as well. Depends how granular you want to be.
Posted: Tue Jun 23, 2015 6:19 pm
by skehole
Sorry if I didn't make it clear. I was wondering if it's easier or better to write the code to have the ra control the regulator, or to use a completely separate ph controller, like a Milwaukee or something similar.
Posted: Wed Jun 24, 2015 6:57 am
Oh screw that, use the RA
That's what you bought it for. Get the PH Expansion or just use your regular PH. Personally I would not buy another piece of equipment that I couldn't manage with my RA. Even if you wanted to get a Milwaukee or similar, I'd still look to get a ph Expansion and monitor that with the RA.
