Excessive ATO chatter with 2 switches
Posted: Tue Jul 28, 2015 9:35 am
I'm getting a LOT of relay 'chatter' with the standard ATO programming and 2 float switches.
It looks like when the water is only about halfway up, the top relay 'chatters'. It's been working fine for weeks, then suddenly the ATO power outlet sounds like a buzz saw it switches so fast. (I don't know what the speed of the loop is, but clearly it's checking more than once per second).
If I lift the float switch by hand, it quits.
At first, I thought I had a defective float switch. Ordered new ones. Been working fine for 2-3 weeks. Now, all new set of float switches, and today the same thing happened. It's not mechanically jammed or anything, and looking at the head unit and moving the float switch with my finger seems to work OK (light goes red, light goes green).
Any ideas?
I could solve this with a bit of code, a manual debounce, but I'm out of the office for 3 weeks and don't want new code to be running with the new guy in the office
Any ideas?
