How would I set a 30 sec delay for my skimmer to come on after I cancel the feed mode?
When pumps are off for a water change or feed mode my sump fills and when I cancel mode the water line is too high for my skimmer and the collection cup fills up. I would like the skimmer to delay a little to give the sump time to empty. What code should I add and where?
Thanks for any help,
Robert
Adding 30 delay to skimmer after feed mode standard library
- Robert1969
Re: Adding 30 delay to skimmer after feed mode standard libr
I think the minimum is 1 minute but I think its ReefAngel.Relay.DelayedOn (Skimmerport, minute);
This is a 5 minute delay...
Example: ReefAngel.Relay.DelayedOn (Port1, 5);
Add this to your setup()
- Robert1969
Did this work for you RobertRobert1969 wrote:Thank you I'll have to give that a try
If you have the Standard Libraries (0.8.3.X), the DelayedOn will not work because it's not included.
DelayedOn will only work on the Development Libraries (0.8.5.X and above...including 0.9.X)
