Serious Bug in ph calibration code
Posted: Sun Aug 02, 2015 12:21 pm
Hi,
There is a bug in the current pH expansion calibration code. If you look at ReefAngel_1.5_LCD.h you see:
What should be there is:
This bug causes the main ph values to be overwritten when you try to calibrate the ph expansion.
Don
InternalMemory.PHMin_write(PHExpMin);
InternalMemory.PHMax_write(PHExpMax);Code: Select all
InternalMemory.PHExpMin_write(PHExpMin);
InternalMemory.PHExpMax_write(PHExpMax);Don
