So my lights are on, but I don't know what percentage they are running at which I currently have them set at 30% with the internal memory. I was told my code looked like it was not set up for internal memory though but I thought that is how I had it. Here is my code:
ReefAngel.FeedingModePorts = Port1Bit | Port4Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardHeater( Port2 );
if ( ReefAngel.Params.Temp[T1_PROBE] < (InternalMemory.HeaterTempOn_read() - 10)) { ReefAngel.Relay.On(Port3); };
if ( ReefAngel.Params.Temp[T1_PROBE] > (InternalMemory.HeaterTempOff_read() - 5)) { ReefAngel.Relay.Off(Port3); };
ReefAngel.SingleATOLow( Port5 );
ReefAngel.Relay.Set(Port8, now()%21600<10800);
ReefAngel.Portal( "MDB1029" );
ReefAngel.DDNS( "Reef" ); // Your DDNS is MDB1029-Reef.myreefangel.com
So my lighting is DIY with LDD drivers so I have the dimming set to 0-5v. I do have channel 0 going to 2 drivers for my whites and channel 1 going to 2 drivers for my blues, Is this a problem?
I am wanting to add the cloud and lightning effect code in here whenever I get the lights working correctly so I don't know if that will change how the code needs to be or not.
On a sidenote, I can't manage to figure out how to run my fuge light. I try to use the wizard and it adds a relay expansion and uses 2 ports there, but all i really want is port 7 to run from 6pm until 10am, I would really appreciate a line of code for this.
Any help with this is greatly appreciated
