Problem with Dimming Expansion
Posted: Wed Aug 12, 2015 9:39 am
by MDB1029
So I have been messing with this for a few days trying to figure out what is wrong but have found no issue with the wiring.
So my lights are on, but I don't know what percentage they are running at which I currently have them set at 30% with the internal memory. I was told my code looked like it was not set up for internal memory though but I thought that is how I had it. Here is my code:
    ReefAngel.FeedingModePorts = Port1Bit | Port4Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit;
    ReefAngel.Relay.On( Port4 );
if ( ReefAngel.Params.Temp[T1_PROBE] < (InternalMemory.HeaterTempOn_read() - 10)) { ReefAngel.Relay.On(Port3); };
if ( ReefAngel.Params.Temp[T1_PROBE] > (InternalMemory.HeaterTempOff_read() - 5)) { ReefAngel.Relay.Off(Port3); };
    ReefAngel.SingleATOLow( Port5 );
    ReefAngel.Relay.Set(Port8, now()%21600<10800);
    ReefAngel.Portal( "MDB1029" );
    ReefAngel.DDNS( "Reef" ); // Your DDNS is MDB1029-Reef.myreefangel.com
I am really hoping there is something wrong here which someone can show me how to fix.
So my lighting is DIY with LDD drivers so I have the dimming set to 0-5v. I do have channel 0 going to 2 drivers for my whites and channel 1 going to 2 drivers for my blues, Is this a problem?
I am wanting to add the cloud and lightning effect code in here whenever I get the lights working correctly so I don't know if that will change how the code needs to be or not.
On a sidenote, I can't manage to figure out how to run my fuge light. I try to use the wizard and it adds a relay expansion and uses 2 ports there, but all i really want is port 7 to run from 6pm until 10am, I would really appreciate a line of code for this.
Any help with this is greatly appreciated
Re: Problem with Dimming Expansion
Posted: Thu Aug 13, 2015 3:59 pm
by binder
it only appears that you are using the onboard pwm ports. nothing is referencing your expansion dimming module. i do not know what that code is offhand but it appears to be non existent.
Posted: Thu Aug 13, 2015 4:06 pm
by binder
MDB1029 wrote: On a sidenote, I can't manage to figure out how to run my fuge light. I try to use the wizard and it adds a relay expansion and uses 2 ports there, but all i really want is port 7 to run from 6pm until 10am, I would really appreciate a line of code for this.
Insert these lines between the "/// Place your custom code below here" and the "/// Place your custom code above here".
The code reads as follows:
if the hour is greater than or equal to 18:00 (which is 6pm) OR if the hour is less than or equal to 10:00, turn on Port 7 of the relay box. Otherwise, if the hour falls outside of that range, turn off Port 7.
The hours run from 0-23. So to span midnight, you need the OR statement to catch both ranges.
if((hour() >= 18) || (hour() <= 10)) {
    ReefAngel.Relay.On(Port7);
} else {
    ReefAngel.Relay.Off(Port7);
