Wifi not working externally.
Posted: Wed Sep 09, 2015 9:20 am
by Sacohen
OK. I need some of those great minds out there to help me figure this out.
Maybe I missed something, but who knows.
I got my WiFi working after I switched to a new Xfinity Router, but it will only work internally I can't access it from Away.
You would think it was port forwarding, but I set up port forwarding exactly like my old router, but with a new internal reserved IP address.
Port 2000 is open according to an online port checker.
Here is the router setup...
I'm pretty sure it has nothing to do with the DDNS because it still does not work if I enter my current IP address:2000 (http://73.139.228.XXX:2000/r99)
FYI, the camera doesn't work either.
Re: Wifi not working externally.
Posted: Wed Sep 09, 2015 2:31 pm
Do you have any other router?
Posted: Wed Sep 09, 2015 2:36 pm
by Sacohen
No. I had a Netgear, but I removed it and am using the Xfinity.
The Netgear worked fine with the setup and I copied the settings before I remove it.
Posted: Wed Sep 09, 2015 7:19 pm
by Sacohen
Roberto;
I'm dealing with Comcast on the Port forwarding issue.
I know it is port 2000.
I need to confirm that it is TCP or UDP or both and if there is an IPV6 IP address.
Posted: Wed Sep 09, 2015 7:36 pm
It's ipv4 and we only use tcp
Posted: Wed Sep 09, 2015 7:47 pm
by Sacohen
Kind of what I thought.
Posted: Thu Sep 10, 2015 7:02 am
by Sacohen
OK. Comcast configured the router for port 2000 to be open to TCP traffic and I still can't get external connectivity, so I'm back to where I was when I originally posted this. STUMPED??? :?: :?: :?:
Posted: Thu Sep 10, 2015 9:19 am
And you are positive that you can access it internally, right?
Posted: Thu Sep 10, 2015 10:41 am
by Sacohen
Yes. 100% positive.
Last connect internal at 8:05 AM this morning.
I couldn't connect at all until last weekend when I realized I had the IP range on my router set to short and the IP address I had reserved for the RA was at the end of the batch.
I changed the reserved IP address to 192.168.1.190 and have been able to connect internally (locally) since then.
Posted: Thu Sep 10, 2015 4:10 pm
Does it do the same thing if you disconnect your phone from wifi and go 3/4G?
Posted: Thu Sep 10, 2015 5:40 pm
by Sacohen
No. It works fine on 3/4G.
The problem is with the WiFi, but I don't know what?
Posted: Thu Sep 10, 2015 6:31 pm
If it works fine with 3/4G, the problem is that your router doesn't support NAT loopback, which means it can't connect to the same ip address where the connection originated from.
I have the same problem on my router :(
But if you are connected to wifi, you can then use the internal ip, right?
Posted: Thu Sep 10, 2015 7:06 pm
by Sacohen
That's correct.
What did you do to get around that issue on your router?
Posted: Thu Sep 10, 2015 7:59 pm
I didn't. I can't connect to my wan ip when I'm home :(
One thing you can try is getting a different router.
Posted: Fri Sep 11, 2015 1:00 am
by Sacohen
Ok. I'll talk with Comcast again and see if they know how to set it up or if they can get me a different router.
I guess I could also use their router to just connect and put my old router back in south of theirs and let it do the work like before.
Posted: Fri Sep 11, 2015 5:47 am
I thought the android app had the home and away profile to handle this circumstance?
Posted: Fri Sep 11, 2015 5:58 am
by Sacohen
You can choose home or away from the drop down up top, but when I'm set to away (like at work) I can't connect to the RA unless I turn off my WiFi and use my data minutes.
Posted: Fri Sep 11, 2015 8:45 am
Oh that's different then. I thought you were talking about only at home
Posted: Fri Sep 11, 2015 8:47 am
by Sacohen
Well it seems to be only from home.
I thought it was from work too, but I just noticed that it is working outside of the house.
Posted: Fri Sep 11, 2015 8:50 am
Yeah. So it is definitely the Comcast router.
Set it to bridge mode and use it only as a modem and then use your other router. You should be able to do it that way.
Posted: Fri Sep 11, 2015 8:54 am
by Sacohen
Yeah or I could switch to home on the app when I'm home.
I thought it was happening when I was out too.
Posted: Sat Sep 12, 2015 5:45 pm
by Sacohen
Thanks for the help.
It is working fine switching between the home and away profile.
I haven't had time to call Comcast and either set it to bridge mode of see if there is a way around the NAT loop back.
Posted: Sun Sep 13, 2015 4:37 am
Some routers also have their own dns servers you can add an entry for your DDNS name so that internally that name will give your internal IP address. Something to look for also as another method.
Posted: Sun Sep 13, 2015 4:47 am
by Sacohen
Thanks. I'll look into that too.
Posted: Sun Sep 13, 2015 7:00 am
by Sacohen
Called Comcast about this issue and they enabled DMX mode for the RA port only.
I know DMZ is less secure, but do you think I will have any security issues?
I do have the server authentication set on the RA.
Posted: Sun Sep 13, 2015 11:28 am
Ahhh. Can u still use dmz on RA and port forwarding on the camera?
Posted: Sun Sep 13, 2015 12:20 pm
by Sacohen
I'm not using the camera anymore.
DMZ on the RA has been working fine.
I was just concerned that it was leaving me vulnerable.
Posted: Sun Sep 13, 2015 1:51 pm
Only if the ra was listening on any other port which it isn't but i basically means you have no port forwarding going on at all
Posted: Sun Sep 13, 2015 1:58 pm
by Sacohen
No. It's just open for that IP address.
