pH climbing
Posted: Thu Sep 17, 2015 8:04 am
by MDB1029
I woke up this morning and the RA tells me my pH is 9.98.
So my first thought was my ATO dumped a ton of kalk in my system and there will be a flood of water to clean up. Well that didn't happen. So I look on the portal and it shows the pH has steadily climbed since last night at 9:00pm.
My crappy pH test kit tells me it is around ~8 and my hanna probe says it is 7.6 after calibration. T then calibrated the RA probe and it is now giving me 10.36.
So last night at about 9pm i uploaded new code with a small amount of change in it but maybe it messed up the probe?
    int DaylightPWMValue=0;        // For cloud code
    ReefAngel.FeedingModePorts = Port1Bit | Port4Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit;
    ReefAngel.Relay.On( Port4 );
    ReefAngel.StandardHeater( Port2 );
if ( ReefAngel.Params.Temp[T1_PROBE] < (InternalMemory.HeaterTempOn_read() - 10)) { ReefAngel.Relay.On(Port3); };
if ( ReefAngel.Params.Temp[T1_PROBE] > (InternalMemory.HeaterTempOff_read() - 5)) { ReefAngel.Relay.Off(Port3); };
    ReefAngel.SingleATOLow( Port5 );
        DaylightPWMValue=PWMSlopeHighRes(10,00,20,0,0,50,60,0);
     CheckCloud();
     ReefAngel.PWM.SetChannelRaw(1,DaylightPWMValue);
    ReefAngel.PWM.SetChannelRaw(0,PWMSlopeHighRes(9,00,21,00,0,45,90,0));  // Blues from 0900 to 2200 on a slope
    ReefAngel.StandardLights(Port7,18,0,10,0);  // Fuge light from 1800 to 1000
    if ( ReefAngel.PWM.GetChannelValueRaw(0) < 16 || ReefAngel.PWM.GetChannelValue(0)>100)
        ReefAngel.PWM.SetChannelRaw(0,16);    // Set a default moonlight value for after hours
    ReefAngel.Portal( "MDB1029" );
    ReefAngel.DDNS( "Reef" ); // Your DDNS is MDB1029-Reef.myreefangel.com
    void CheckCloud()
    #define Clouds_Every_X_Days 1
    #define Cloud_Chance_per_Day 60
    #define Min_Cloud_Duration 7
    #define Max_Cloud_Duration 21
    #define Min_Clouds_per_Day 1
    #define Max_Clouds_per_Day 5
      // In this example, start cloud after noon
    #define Start_Cloud_After NumMins(11,00)
    #define End_Cloud_Before NumMins(19,00)
    #define Lightning_Change_per_Cloud 75
      // Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes
      // of effects or unforseen result could happen.
      // In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the
      // 250 minutes (or 500 minutes) can fit in that 510 minutes window.
      // Add Random Lightning modes
    #define Calm 0    // No lightning
    #define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
    #define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
    #define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
    #define Mega2 4   // Like Mega, but with more lightning
      // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
      // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
      byte LightningModes[] = {Mega2,Mega,Mega,Calm,Calm,Fast,Fast};
      static byte cloudchance=255;
      static byte cloudduration=0;
      static int cloudstart=0;
      static byte numclouds=0;
      static byte cloudindex=0;
      static int LastNumMins=0;
      static byte lightningMode=0;
      static time_t DelayCounter=millis();    // Variable for lightning timing.
      static int DelayTime=random(1000);      // Variable for lightning timimg.
    #ifdef forcecloudcalculation
      if (cloudchance==255)
    #else
    #endif
          randomSeed(millis());    // Seed the random number generator
          cloudchance=random(100);
          // If we have cloud today
          if (cloudchance)
            lightningchance=random(100);
      if (cloudchance)
        //is it time for cloud yet?
          DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue/40.95,0,180)*40.95;
          if (chooseLightning)
            chooseLightning=false;
          switch (lightningMode)
          case Calm:
            break;
          case Mega:
            // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
              // Send the trigger
              Strike();
              DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
              DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
            break;
          case Mega2:
            // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
              Strike();
            break;
          case Fast:
              Strike();
            break;
          case Slow:
            // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
              else lightningstatus=0;
              if (lightningstatus)
                DaylightPWMValue=4095;
                DaylightPWMValue=0;
              delay(1);
            break;
          default:
            break;
          cloudindex++;
          if (cloudindex < numclouds)
        /*ReefAngel.LCD.Clear(255,0,120,132,132);
         ReefAngel.LCD.DrawText(0,255,51,120,"00:00"); */
          int x=0;
          else x=17;
          //ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart/60));
          ReefAngel.CustomVar[3]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
          else x=35;
          //ReefAngel.LCD.DrawText(0,255,x,120,(cloudstart%60));
          ReefAngel.CustomVar[4]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
        //ReefAngel.LCD.DrawText(0,255,90,120,cloudduration);
        ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
        if (lightningchance)
          int x=0;
          if (((cloudstart+(cloudduration/2))/60)>=10) x=51;
          else x=57;
          //ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))/60));
          ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
          if (((cloudstart+(cloudduration/2))%60)>=10) x=69;
          else x=75;
          //ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60)); // Write the minute of the next lightning to a custom variable for the Portal
            ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))%60;
    void Strike()
      int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
      for (int i=0; i<a; i++)
        // Flash on
        int newdata=4095;
        Wire.beginTransmission(0x40);      // Address of the dimming expansion module
        Wire.write(0x8+(4*1));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 1.
        Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
        Wire.write(newdata>>8);            // This sends the MSB
        Wire.endTransmission();
        int randy=random(20,80);    // Random number for a delay
        if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
        delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
        // Flash off.  Return to baseline.
        newdata=ReefAngel.PWM.GetChannelValueRaw(1);   // Use the channel number you're flashing here
        Wire.beginTransmission(0x40);    // Same as above
        delay(random(30,50));                // Wait from 30 to 49 ms
        wdt_reset();    // Reset watchdog timer to avoid re-boots
      cstart*=60;
      cend*=60;
      if (n>cend) return (int) PWMStart;
The only things i touched were the max percentage of channel 0 and 1, and also the parameters for the lightning regarding frequency and duration and such.
Could I have done something that effected the pH probe?
Re: pH climbing
Posted: Thu Sep 17, 2015 9:15 am
Does it show the same readings if you place the probe in a cup of tank water?
Re: pH climbing
Posted: Thu Sep 17, 2015 9:22 am
by MDB1029
rimai wrote:Does it show the same readings if you place the probe in a cup of tank water?
Since I calibrated the probe it has started to climb faster.
I have it in tank water in a cup and it is still showing the same reading at this point.
Re: pH climbing
Posted: Thu Sep 17, 2015 10:22 am
What were the numbers you got when calibrating?
Re: pH climbing
Posted: Thu Sep 17, 2015 8:39 pm
by MDB1029
I don't remember exactly but they were something like 545 and 600. I can recalibrate and record those numbers if you need the actual numbers. The pH is 14.00 currently i think it has stopped.
Just to make sure I am calibrating correctly, does the calibration process take about 5-10 minutes? The number moves very slowly. Am I taking too long, not long enough?
Re: pH climbing
Posted: Thu Sep 17, 2015 9:00 pm
600 for pH10 doesn't sound right.
Re: pH climbing
Posted: Thu Sep 17, 2015 9:46 pm
by MDB1029
That is what i thought when i was calibrating but i put it in the solution and it sat at 545 for about a minute and then jumped a couple times and then sat at 600
Re: pH climbing
Posted: Wed Sep 23, 2015 7:55 am
by MDB1029
Does 746 sound like a correct # for the 7.0 solution on the calibration?
Re: pH climbing
Posted: Wed Sep 23, 2015 9:11 am
No. Seems your probe may need to be replaced then.
It should be around 500's for 7.0 and around 800's for 10.0
Re: pH climbing
Posted: Wed Sep 23, 2015 10:56 am
by MDB1029
So i recalibrated again today and it was 545 for 7 and 767 for 10. However, after calibration the probe was reading 8.69 and now climbing again at 9.18 right now.
Re: pH climbing
Posted: Wed Sep 23, 2015 4:10 pm
Numbers seem to be not too bad.
Is it climbing on a cup of tank water too?
Re: pH climbing
Posted: Wed Sep 23, 2015 10:19 pm
by MDB1029
So this is what it did before
And after calibrating it today it began to rise again and then just dropped to what may be the correct pH value. I tried to get a picture of the most recent chart but my computer is one step above a paperweight and can't manage to download the image.
So it seems like it is working but i can't verify the value against anything reliable.
Is there any reason you can think of why it is doing this? Do you think the probe is the problem? of code?
