IOs 9 - Dimming Override -> Stuck
joaocdestro
When I try to override some values in Dimm expantion in the RF Iphone APP it get stuck, freeze the app.
Regards,
Joao C. Destro
Joao C. Destro
Re: IOs 9 - Dimming Override -> Stuck
Was it working before on a previous version OS or you never tried it with a different OS?
Christo
IOS 9 Is heavily flawed!!!! Causes a lot of apps to crash.
- lnevo
It worked ok for me but the app crashed a few times and it seems a little choppy, same for changing the RF.
joaocdestro
app in IOS 8 OK
https://youtu.be/awafimv3OIA
app in IOS 9 stuck after dimm change
https://youtu.be/HxrTwY6uUgU
Regards,
Joao C. Destro
Joao C. Destro
joaocdestro
app in IOS 8 OKrimai wrote:Was it working before on a previous version OS or you never tried it with a different OS?
Regards,
Joao C. Destro
Joao C. Destro
JoelIreland
Having same issue with it crashing on iPhone 6 with iOS9 ( it wont adjust dimming ) but on iPad air with iOS 9 it adjusts the dimming and freezes.
- lnevo
This is becoming more of an issue. Tried setting the dim yesterday and it kept crashing me out of the app.
skehole
I don't use the uapp for dimming, but it won't let me into the setting on my controller anymore. It just defaults back to the home screen
fckgravity
I am getting the same issues as all of the above. with a 6s and ios 9.0.2
Civics14
Same issue here - any possibility of updating the app to be compatible with ios 9?
It's in the works.
Unfortunately, the iOS9 broke core functionality and the entire app has to be redesigned.
- Contact:
yuck. stupid ios....doing it again to us like they did with 7 (i think).rimai wrote:It's in the works.
- lnevo
It doesn't seem that broken. Out of curiosity what did they change that requires such a big redesign?rimai wrote:It's in the works.
We use jquery and jquery ui as our user interface framework and it doesn't work well on ios9.
So, I'm changing it to angularjs
