Remote hub for temp and float switches
Posted: Wed Sep 23, 2015 9:55 am
by cosmith71
I'm thinking about relocating my RA from the stand to a cabinet located next to the tank. I'd like to make a little hub to place under the stand so I can plug/unplug the temp probes and the float switches there instead of having to follow cables back and forth from the stand to the cabinet.
I was thinking of having a breakout box with the following lines from the RA (thinking ethernet cable):
Ground (from one of the float switch ports or temp ports)
+5v from a temp port
ATOLow+
ATOHigh+
Signal line from a temp port
On the breakout box, I'd have a jack for ATOLow, ATOHigh (ATO lines and the ground) and 3 jacks for temp probes connected to ground, +5v, and temp signal.
Any obvious problems with this setup?
Re: Remote hub for temp and float switches
Posted: Wed Sep 23, 2015 9:59 am
You should be fine :)
Posted: Wed Sep 23, 2015 10:14 am
by cosmith71
Oh, and a pH extension, too. I'll probably just use a BNC extension cable for that.
Posted: Sat Sep 26, 2015 12:34 pm
by cosmith71
So I got this done. I basically glued some 3 pin and 2 pin connectors (jumper wires, really) together. It works, but it's ugly and one of the 2 pin connectors broke almost immediately. I found this on Amazon for version 2.0.
https://www.amazon.com/gp/aw/d/B00OVDU4 ... UTF8&psc=1
I think I'll mount it to a small PCB with sturdier 2 pin connectors. May use pieces of header strip.
Posted: Sun Sep 27, 2015 4:19 pm
Pretty cool :)
Posted: Sat Oct 03, 2015 9:41 am
by cosmith71
v2.0 is done.
Posted: Sun Oct 04, 2015 9:57 am
by Kungpaoshizi
Nice job :)
Posted: Sun Oct 04, 2015 10:13 am
by cosmith71
Posted: Fri Dec 18, 2015 1:18 pm
by GiraffeCat
Very Nice! Does that eliminate any "stress" on the sensor Bus? Any chance you are going to get with Roberto/some other smart guy and make a RANet version?
Posted: Fri Dec 18, 2015 1:26 pm
by GiraffeCat
Also, is the knob on your RA Broken? It looks off center in the picture. Again, nice job on that.
Posted: Fri Dec 18, 2015 3:40 pm
by cosmith71
It's not broken, just the angle of the picture I suppose.
It's only purpose is to simplify the wires going from under my tank to the cabinet beside my tank where the RA is. It's extremely simple.
