relay expansion help
Posted: Tue Sep 29, 2015 5:28 pm
by fishflipper
i just installed a expansion relay box and nothing i plug into it powers on. when i connect it to power and plug the serial cable into the expansion hub, the light on the expansion box lights. any ideas??
Re: relay expansion help
Posted: Tue Sep 29, 2015 5:29 pm
Try changing the ID.
Posted: Tue Sep 29, 2015 5:36 pm
by fishflipper
i took the box apart and didn't see the dip switches to do that. shouldn't it power on even if not connected to the controller?
Posted: Tue Sep 29, 2015 5:40 pm
by fishflipper
i found the switches and changed and it didn't help.
Posted: Tue Sep 29, 2015 5:42 pm
Try with them all on and also with them all off.
Posted: Tue Sep 29, 2015 5:44 pm
by fishflipper
still no power. shouldnt it work just plugged into the wall by itself?
Posted: Tue Sep 29, 2015 5:46 pm
What do you mean work just plugged into the wall?
Posted: Tue Sep 29, 2015 5:47 pm
by fishflipper
without being connected to the controller.
Posted: Tue Sep 29, 2015 5:48 pm
If it is not connected to the controller, nothing will turn on.
The controller is the one that tells which ports to turn on.
Run I2Cscanner and send the results:
http://forum.reefangel.com/viewtopic.php?p=18831#p18831
Posted: Tue Sep 29, 2015 5:59 pm
by fishflipper
i uploaded the code and now the controller is just blinking red
Posted: Tue Sep 29, 2015 6:02 pm
keep following the instructions on the link.
send the results on serial monitor
Posted: Tue Sep 29, 2015 6:06 pm
by fishflipper
this is what happens when i plug the expansion box in directly to the controler. things flash on for a sec then off
I2CScanner ready!
starting scanning of I2C bus from 1 to 128...
addr: 1 addr: 2 addr: 3 addr: 4
addr: 5 addr: 6 addr: 7 addr: 8
addr: 9 addr: A addr: B addr: C
addr: D addr: E addr: F addr: 10
addr: 11 addr: 12 addr: 13 addr: 14
addr: 15 addr: 16 addr: 17 addr: 18
addr: 19 addr: 1A addr: 1B addr: 1C
addr: 1D addr: 1E addr: 1F addr: 20 found!
addr: 21 addr: 22 addr: 23 addr: 24
addr: 25 addr: 26 addr: 27 addr: 28
addr: 29 addr: 2A addr: 2B addr: 2C
addr: 2D addr: 2E addr: 2F addr: 30
addr: 31 addr: 32 addr: 33 addr: 34
addr: 35 addr: 36 addr: 37 addr: 38
addr: 39 addr: 3A addr: 3B addr: 3C
addr: 3D addr: 3E addr: 3F addr: 40
addr: 41 addr: 42 addr: 43 addr: 44
addr: 45 addr: 46 addr: 47 addr: 48
addr: 49 addr: 4A addr: 4B addr: 4C
addr: 4D addr: 4E addr: 4F addr: 50 found!
addr: 51 addr: 52 addr: 53 addr: 54 found!
addr: 55 addr: 56 addr: 57 addr: 58
addr: 59 addr: 5A addr: 5B addr: 5C
addr: 5D addr: 5E addr: 5F addr: 60
addr: 61 addr: 62 addr: 63 addr: 64
addr: 65 addr: 66 addr: 67 addr: 68 found!
addr: 69 addr: 6A addr: 6B addr: 6C
addr: 6D addr: 6E addr: 6F addr: 70
addr: 71 addr: 72 addr: 73 addr: 74
addr: 75 addr: 76 addr: 77 addr: 78
addr: 79 addr: 7A addr: 7B addr: 7C
addr: 7D addr: 7E addr: 7F addr: 80
Posted: Tue Sep 29, 2015 6:09 pm
by fishflipper
here is the monitor with everything plugged back in
I2CScanner ready!
addr: 39 addr: 3A addr: 3B addr: 3C found!
addr: 45 addr: 46 addr: 47 addr: 48 found!
addr: 4D found! addr: 4E addr: 4F found! addr: 50 found!
Posted: Tue Sep 29, 2015 6:11 pm
3C is ID 5
it should be 38.
by fishflipper
so....what does that mean?
Posted: Tue Sep 29, 2015 6:17 pm
Your module is set to ID5. You need to set it to ID1.
When you set to ID1, it will be found as 38 instead of 3C.
Posted: Tue Sep 29, 2015 6:23 pm
by fishflipper
is this better? how do you read this?
I2CScanner ready!
addr: 39 found! addr: 3A addr: 3B addr: 3C
done
Posted: Tue Sep 29, 2015 6:47 pm
Almost. It found 39.
It needs to be 38
Posted: Tue Sep 29, 2015 6:54 pm
by fishflipper
still not working
I2CScanner ready!
addr: 35 addr: 36 addr: 37 addr: 38 found!
done
Posted: Tue Sep 29, 2015 6:55 pm
There ya go.
38.
Now, upload your code.
Posted: Tue Sep 29, 2015 6:56 pm
by fishflipper
here is the code i uploaded and it is still not working.
ReefAngel.AddPHExpansion(); // pH Expansion Module
ReefAngel.AddHumidityExpansion(); // Humidity Expanion Module
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit;
ReefAngel.LightsOnPorts = Port7Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit;
// Ports turned off when Leak is detected
ReefAngel.LeakShutoffPorts = Port8Bit;
ReefAngel.LeakShutoffPortsE[0] = 0;
InternalMemory.OverheatTemp_write( 835 );
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardLights( Port7,13,0,22,30 );
ReefAngel.WaterLevelATO( Port8,25,80,90 );
if (ReefAngel.WaterLevel.GetLevel()>0 && ReefAngel.WaterLevel.GetLevel() < 80) ReefAngel.Relay.On(Port8);
if (ReefAngel.WaterLevel.GetLevel() >=85) ReefAngel.Relay.Off(Port8);
ReefAngel.Portal( "fishflipper" );
ReefAngel.DDNS( "nickgrill.getmyip.com" ); // Your DDNS is fishflipper-nickgrill.getmyip.com.myreefangel.com
Posted: Tue Sep 29, 2015 7:09 pm
Humm.
Can you swap svga cables with the main box?
If it still doesn't work, can you test the relay box itself as the main box?
Posted: Tue Sep 29, 2015 7:12 pm
by fishflipper
when connecting the box directly to the controller it does work.
Posted: Tue Sep 29, 2015 7:16 pm
by fishflipper
ugh!!! all this and its seems to be the expansion hub. plugged the relay into my other hub and the lights came on. do the expansion hubs just plug into each other to work, right? the light was on so i thought it was working.
Posted: Tue Sep 29, 2015 7:50 pm
No, you can only use one hub per system.
The signal won't propagate to the 2nd hub.
Posted: Tue Sep 29, 2015 7:55 pm
by fishflipper
Oh, really? Any future thoughts of adding it? Can the usb port on the expansion box still be used?
Sent from my SAMSUNG-SM-G900A using Tapatalk
Posted: Wed Oct 07, 2015 3:16 pm
by fishflipper
Robert, i just want to say thank you for the quick replies and the help on this matter the other night. everything is working great! i do have one more question though.....i know you said only one expansion hub is supported but can the usb port on the expansion module still be used?
Posted: Wed Oct 07, 2015 3:41 pm
No. It can't.
Did you run out of ports in the hub?
Posted: Wed Oct 07, 2015 3:57 pm
by fishflipper
No, not yet. This relay box is on a second tank with a 15 foot usb cable and I only had one so was hoping to not have to run another one to the hub.
