dual ATO's
jsclownfish
dual ATO's
Post by jsclownfish »
I want to fit two small reservoirs under my stand with separate pumps so I don't have to add fill the top off tanks as often. I have two of float switches installed to determine which reservoir is full. Will it work OK if I have two ATO functions like this?
void CheckLevels()
  //Overflow blocked alarm & main pump shut-off, Reservoir
  if (Overflow == 1) ReefAngel.Relay.Off(Mainpump);
  else ReefAngel.Relay.On(Mainpump);
  if (ReservoirA == 0)
    ReefAngel.StandardATO(ATOpump);
    ReefAngel.Relay.Off(ATOpump);
    if (ReservoirB == 0) ReefAngel.StandardATO(ATOpump2);
    else ReefAngel.Relay.Off(ATOpump2);
Re: dual ATO's
I don't see why it wouldn't work :)
