older PWM?
Posted: Fri Oct 02, 2015 11:37 am
by CHAOS
I have a PWM 2.1
I opened it up and didnt see the jumpers for 5/10v and analog/pwm.
Does the 2.1 have analog capabilities?
can it switch from 5-10, or which one is it?
Thanks.
Re: older PWM?
Posted: Fri Oct 02, 2015 4:39 pm
It is 0-10V PWM only.
If you need 0-5V or analog, you will need a new one.
Re: older PWM?
Posted: Fri Oct 02, 2015 10:29 pm
by CHAOS
Ouch bummer, can the RA run any lights without the expansion? If so, is it analog?
Re: older PWM?
Posted: Sat Oct 03, 2015 8:46 am
The relay box has 2 dimming ports. They are most likely 0-10v pwm unless you opted for analog when you bought it.
Re: older PWM?
Posted: Sat Oct 03, 2015 6:47 pm
by CHAOS
How can I tell?
Re: older PWM?
Posted: Sat Oct 03, 2015 7:01 pm
Should be a sticker if its analog
Re: older PWM?
Posted: Sat Oct 03, 2015 10:10 pm
by CHAOS
Im not seeing anything anything on the outside, would it be inside?
Re: older PWM?
Posted: Sun Oct 04, 2015 3:34 am
by cosmith71
The sticker is generally on the bottom of the unit.
