Does 300 Watt heater exceed RA specs?
Posted: Mon Oct 05, 2015 11:36 am
by paperdesk
I have a 300 watt heater. Is it ok to plug into the RA relay box, or does it exceed the specs? I'm wondering if it would be better to use two smaller heaters.
Ted
Re: Does 300 Watt heater exceed RA specs?
Posted: Mon Oct 05, 2015 11:47 am
by Lionfan
paperdesk wrote:I have a 300 watt heater. Is it ok to plug into the RA relay box, or does it exceed the specs? I'm wondering if it would be better to use two smaller heaters.
Ted
Really depends on the amps.
I'm running a 500 watt Finnex on mine, with no problems.
Posted: Tue Oct 06, 2015 4:53 am
by cosmith71
5A per outlet, with a 10A max for the box.
300W/120v = 2.5A (assuming you're in the US) so you should be fine.
Posted: Tue Oct 06, 2015 7:30 am
by paperdesk
Thanks guys! I wasn't able to find those specs.
