Problem with Serial TTL port or cable.
Posted: Wed Oct 14, 2015 7:21 pm
I have been having some problems with my neiw internet provider (Comcast) and th elast time I was on the phone with them they had me reset the router to factory specs.
This defaults the router to a 10.0.0.1 gateway.
So I tried running the WiFi Utility to re-configure the WiFi to 10.0.0.1 instead of 192.18.1.254 that it was with my old router,
The WiFi utility will not connect to the WiFi module on Port 3.
When I reformatted my PC (Windows 7) I never really installed the drivers and set it up to connect using the Serial TTL cable because I use the Bluetooth module.
So I uninstalled the RA software and tried to re-install it and after it installs the drivers and says to plug in the TTL cable to the unit and USB port and wait until the hardware is installed it never does that part.
The hardware never gets installed.
This makes me think that there may be and issue with the Serial TTL port or cable, because both of these procedures use the TTL port and cable and both don't work like they should.
I have tried removing and reinstalling the software and nothing changes.
Any suggestions?
Any suggestions?
