I switched from Bellsouth (or AT&T) DSL to Comcast Xfinity about a month a go and have had problems with my WiFi Module connecting to the internet since.
I've gotten it connected a couple of times, but it typically lasts 2-3 days and then I lose connectivity to the portal and the Android app inside my house or out of my network and just around anywhere.
What I've noticed is that when I lose connectivity the portal will show the correct Static IP address that Comcast has assigned to me (73.139.228.XXX), but when I start checking thing to see what the problem is the online IP checkers will show what I believe is the Iv6 IP address of 2601:582:c001:784f1:6a0c:xxXX:xxxX.
The RA only uses the Iv4 IP address and not the Iv6 address. I know this from speaking with Roberto when trying to setup my port forwarding about a month ago and the Comcast tech was asking for the Iv6 address of the RA to set it up. Roberto told me they don't use the Iv6 protocol.
So after that lengthy backstory my question has 2 parts to it.
1) Who has internet service with Comcast?
2) How do you deal or get around this issue?
Thanks in advance.
