Reset PH values to default?
Posted: Wed Oct 21, 2015 5:08 am
by Poiromaniax
Hi guys,
I have recently noticed my ph probe is reading extremely low readings. like 4
When i put it in the 7 solution, the value goes down to zero and stays there. When i put in 10 solution it goes up to 100 and something.
Is there a way to reset the values to default (think its around the 400 mark) and then calibrate from there?
Or is my PH probe starting to say its goodbyes? (Ive had it for about 3 years or so)
Re: Reset PH values to default?
Posted: Wed Oct 21, 2015 1:27 pm
RIP probe :(
You need to get calibration fluid and retry the calibration, but most likely it's toast especially after 3 years.
Posted: Thu Oct 22, 2015 2:44 am
by Poiromaniax
I do have the fluid but as I say it just bottoms out to 0.
Oh well - 3 years is a good run
Posted: Thu Oct 22, 2015 5:26 am
Sorry didn't realize you were giving the calibration values. Yeah probe is definitely shot :) 3 years is definitely a good run. I went through 3 in my first two years. The last one has been going strong at least 1.5 now.
Posted: Thu Oct 22, 2015 5:32 am
by Poiromaniax
Ok cool.
Thanks man - at least they aren't too expensive
Posted: Sun Oct 25, 2015 10:49 pm
by Poiromaniax
Out of interest - would one be able to use any PH probe with a BNC connection? or does it need to be the RA one?
Posted: Mon Oct 26, 2015 5:25 am
by cosmith71
Pretty much any one. Make sure they're waterproof (not all are, especially the super cheap ones).
The RA one is actually a nice balance of price and quality. Any of the less expensive probes will go out in a year or so.
Posted: Mon Oct 26, 2015 12:12 pm
by Poiromaniax
Cool, so can always get a more expensive/better quality one if one would want
Posted: Mon Oct 26, 2015 3:26 pm
After changing it a couple of times, i bought the lab grade from neptune and its been running strong. Used the pinpoint and a brs one as well.
