2 dimming expansion modules
Posted: Tue Nov 03, 2015 5:38 am
by cliffwagner1
I have searched and cannot find support for running 2 dimming expansions. I am going to run 3 each 3 channel lights independently. Can anyone help me out or do I need to pull the trigger on a 16 channel from rimai?
Re: 2 dimming expansion modules
Posted: Tue Nov 03, 2015 10:31 am
Both options won't give you visibility on the portal
Only the first module will show up.
You can control them, but you would not see the values on the portal or any app we have out there.
The code to control both of them would be the same.
It's been integrated into the libraries by another user
Posted: Thu Nov 05, 2015 4:51 pm
by cliffwagner1
So, I suppose now I have a request for portal and/or android app support. Any chance of getting that done?
Posted: Fri Nov 06, 2015 5:46 am
You could use the Custom variables as a proxy and then you'd see the channels and be able to set them if desired.
Posted: Fri Nov 06, 2015 7:22 pm
so it's simply adding in a second standard dimming module?
based on Robertos comments, it sounds like the data gets sent if enabled. is that correct? of course it's in the dev branch and it will eventually make it into the main release.
Sent from my XT1060
