ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit;
ReefAngel.FeedingModePortsE[0] = Port5Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port6Bit | Port7Bit;
ReefAngel.WaterChangePortsE[0] = Port5Bit;
ReefAngel.LightsOnPorts = Port4Bit | Port5Bit | Port8Bit;
ReefAngel.LightsOnPortsE[0] = Port1Bit | Port2Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port5Bit;
// Setup ATO Port for AI communication
ReefAngel.AI.SetPort( lowATOPin );
ReefAngel.Relay.On( Port2 );
ReefAngel.StandardHeater( Port3,780,785 );
ReefAngel.StandardFan( Port4,785,790 );
ReefAngel.StandardLights( Port5,22,0,6,0 );
ReefAngel.Relay.DelayedOn( Port6,1 );
ReefAngel.WaterLevelATO( Port7,60,90,100 );
ReefAngel.StandardLights( Box1_Port1,8,0,20,0 );
ReefAngel.StandardLights( Box1_Port2,12,0,18,0 );
ReefAngel.DosingPumpRepeat( Box1_Port3,0,30,240 );
ReefAngel.DosingPumpRepeat( Box1_Port4,30,30,240 );
ReefAngel.StandardLights( Box1_Port8,9,0,19,0 );
ReefAngel.PWM.SetDaylight( PWMParabola(6,0,22,0,0,100,0) );
ReefAngel.PWM.SetChannel( 0, PWMParabola(7,0,22,0,0,75,0) );
ReefAngel.PWM.SetChannel( 1, PWMParabola(7,0,22,0,0,75,0) );
ReefAngel.PWM.SetChannel( 2, PWMSlope(10,0,18,0,0,65,120,0) );
ReefAngel.AI.SetChannel( White, PWMParabola(11,0,18,0,0,75,0) );
ReefAngel.AI.SetChannel( Blue, PWMParabola(8,0,21,0,1,100,1) );
ReefAngel.AI.SetChannel( RoyalBlue, PWMParabola(8,0,22,0,1,100,1) );
ReefAngel.DCPump.SetMode( Else,50,10 );
ReefAngel.DCPump.ExpansionChannel[0] = None;
ReefAngel.DCPump.ExpansionChannel[3] = Sync;
ReefAngel.DCPump.ExpansionChannel[4] = AntiSync;
ReefAngel.DCPump.ExpansionChannel[5] = AntiSync;
if(ReefAngel.HighATO.IsActive())
ReefAngel.Relay.Override(Port6,0);
ReefAngel.Portal( "lionfan" );
