Multiple Light On Times
Posted: Thu Dec 10, 2015 11:21 pm
by tmoore103
Hello fellow reefers,
I'm a newbie to both coding and the ReefAngel system so I'm hoping you pros can help me out.
I got my system a few weeks ago for my nano reef and I absolutely love it! This will probably be pretty easy for you guys.
I'm trying to turn a port on at multiple scheduled times ( from 10 am to 11am and again from 11 pm to 7 am ) but I can't seem to figure it out. I've searched all over the forum but I can't seem to find what I'm looking for. So far I've tried these lines but couldn't get them to work.
First:
ReefAngel.StandardLights( Port3,10,0,11,0 );
if (bitRead(ReefAngel.Relay.RelayData,Port3)==0) ReefAngel.StandardLights( Port3,22,0,7,0 );
Then I thought maybe I was just complicating things so I tried this:
Then this:
if (hour()>=10 && hour()<11)
ReefAngel.Relay.On ( Port3 );
I was getting an upload error when I tried the last so I tried adjusting the code a little. It eventually let me upload the last one but it doesn't look like it's working. Any help would be greatly appreciated.
-Tori
Re: Multiple Light On Times
Posted: Fri Dec 11, 2015 5:50 am
by cosmith71
Try this:
if ((hour()>=10 && hour()<11) || (hour()>=23 || hour()<7))
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.Off(Port3);
Or, more succinct and not as easy to understand (does the same thing)
if (hour()==10 || hour()==23 || hour()<7)
Lots of ways to do it.
Posted: Fri Dec 11, 2015 8:37 pm
by tmoore103
Thanks Colin! Really appreciate the help man. Thanks for showing me more than one way to do it.
Posted: Sat Dec 12, 2015 6:09 am
by cosmith71
No problem.
Posted: Thu Apr 07, 2016 4:12 pm
by bkc6868
If the port is already programmed for a certain time to come on by the wizard and we use this code, does the wizard code have to be deleted for that port? I have that port set to come on from 2 till 10 , but want to use this for multiples times instead. I used the code and it come on at the time I set but didn't go off
Posted: Fri Apr 08, 2016 4:51 am
by cosmith71
Whatever comes last in the code takes priority. Post your code and what you want to happen.
Posted: Fri Apr 08, 2016 12:28 pm
by bkc6868
I used this code but changed the times in it to 10 a.m. on and off 2 p.m. I the wizard the port is supposed to run till 2pm till 10pm. After loading this cusom code with my time changes it cam on at 10a.m. but didnt shut off at 2p.m like the custom code was supposed to do them back on at 6pm till 10 pm
by bkc6868
double post.. sorry
Posted: Fri Apr 08, 2016 12:49 pm
by cosmith71
The wizard code and the new code will conflict. We need to see the whole code you are using.
Posted: Fri Apr 08, 2016 4:27 pm
Most likely we will want to take the wizard code and have the lights come on from 10am till 10pm then add a statement to turn them off between 2pm and 6pm
Posted: Sat Apr 09, 2016 11:19 am
by bkc6868
Here is my wizard code. I took the custom code from above out
[/co#include <ReefAngel_Features.h>
ReefAngel.FeedingModePorts = Port2Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port6Bit | Port7Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardFan( Port1,785,790 );
ReefAngel.StandardLights( Port3,14,0,22,0 );
ReefAngel.StandardLights( Port5,6,0,18,0 );
ReefAngel.StandardLights( Port6,14,0,22,0 );
ReefAngel.StandardHeater( Port7,780,785 );
ReefAngel.SingleATO( false,Port8,180,0 );
ReefAngel.Portal( "bkc6868" );
ReefAngel.DDNS( "www.reefangel.com" ); // Your DDNS is bkc6868-www.reefangel.com.myreefangel.com
de]
Posted: Sat Apr 09, 2016 3:01 pm
by cosmith71
Specifically, which ports do you want to run at what times? I'm still not sure what you're trying to do.
Posted: Sat Apr 09, 2016 3:15 pm
by bkc6868
Port 3 from 10am to 2 pm and again at 6 pm to 10 pm
Posted: Sat Apr 09, 2016 3:22 pm
by cosmith71
Change this line:
to this:
ReefAngel.StandardLights( Port3,10,0,22,0 );
if (hour() >=14 && hour() <18) ReefAngel.Relay.Off(Port3);
Posted: Sat Apr 09, 2016 3:37 pm
by bkc6868
Thank you!
