Changing parameters via web
Posted: Thu Dec 17, 2015 10:08 am
by KCReefer
I use 3 dosing pumps and any time that I want to change the schedule for them, I have to physically connect my laptop to the controller and upload the code that has only changed 3 values. Does anyone know of a way to change dosing schedule from anywhere using the wifi module? Any help would be appreciated!
Re: Changing parameters via web
Posted: Thu Dec 17, 2015 3:19 pm
You need to switch to memory in the wizard instead of hard coded. Then you can change them in the portal.
Posted: Fri Dec 18, 2015 5:13 am
by binder
lnevo wrote:You need to switch to memory in the wizard instead of hard coded. Then you can change them in the portal.
or from one of the apps. :lol:
Posted: Fri Dec 18, 2015 10:10 am
by KCReefer
Awesome! I've always been afraid to switch to in memory because of the warning that is stated that I will need external tools to update the code. If I store the code in memory, am I forced to use the portal (or other external tools) to make changes to my logic or would I be able to run the wizard again?
Posted: Fri Dec 18, 2015 10:17 am
by binder
you can definitely run the wizard again if you wanted to change the memory values. it would be more tedious than the portal or app, but still doable.
Posted: Fri Dec 18, 2015 10:40 am
by KCReefer
That definitely puts my mind at ease. Thanks! Do you have to send commands through api calls in the url or is there an interface in the portal to change scheduled values?
Posted: Fri Dec 18, 2015 10:52 am
In the portal under internal memory. Which mobile app are you usong.
Posted: Fri Dec 18, 2015 11:14 am
by KCReefer
awesome!
I am currently not using an app. I have an iphone and the last I heard is that authentication is not supported with the iphone app, so I have a shortcut on my home screen to point to the portal. I use the portal on my laptop for the most part.
Posted: Fri Dec 18, 2015 12:56 pm
by binder
yeah, you will be fine then.
Posted: Wed Dec 23, 2015 2:44 pm
by KCReefer
that was more painless than I thought. I can't believe I spent that long uploading code every time I wanted to change dosing schedules. Now I can start mixing some in code functions (shutting off skimmer when waste container is full, solenoid valve timers, etc) and I'm set. Thanks for your help
