RA ruined my ATI fixture
Posted: Sun Dec 27, 2015 12:51 pm
by Lionfan
Out of nowhere my RA started randomly and violently clicking power on and off to one of the modules. Considering I just got a replacement Relay Expansion and the expansion hub is only a few weeks old, theyre not the problem.
I'm about done with RA.
Now, after the power flashes, all 3 of my ballasts are blown, and its going to cost me $180 to fix it.
So, what could have been the problem?
Re: RA ruined my ATI fixture
Posted: Sun Dec 27, 2015 1:47 pm
Was it the main box or expansion that was doing that?
Posted: Sun Dec 27, 2015 3:27 pm
by Lionfan
rimai wrote:Was it the main box or expansion that was doing that?
Expansion
Posted: Mon Dec 28, 2015 7:43 pm
Did you use the new USB cable that came with the new hub?
This seems to be a bad connection somewhere.
Could it be in the USB port in the main box?
Posted: Tue Dec 29, 2015 11:34 am
by Lionfan
rimai wrote:Did you use the new USB cable that came with the new hub?
That could be it.
I used the new USB cord.
I have a another RA set up, and I can switch the relay boxes to see if that's causing it.
It's not as crazy as it was, but it is still randomly cycling power, and it now i have random dimming flashes.
Posted: Wed Dec 30, 2015 10:13 pm
by Lionfan
Im starting to notice that I only get the power blinking when my daylights are on.
Do you think there is too much power getting pulled thru the relay expansion?
Not sure what's happening with the dimming blinking, but it might explain the power cycles
Posted: Wed Dec 30, 2015 10:21 pm
Whenever there is a bus lock, the dimming channel may do that.
Posted: Fri Jan 01, 2016 9:34 am
by Lionfan
rimai wrote:Whenever there is a bus lock, the dimming channel may do that.
So a bus lock is causing the power cycles?
Posted: Fri Jan 01, 2016 12:04 pm
That's what I'm thinking.
Posted: Fri Jan 01, 2016 6:18 pm
by Lionfan
rimai wrote:That's what I'm thinking.
So what could be causing the bus lock I wonder? Most everything is new.
Except the water level sensor.
I'll unplug it tonight and see how it acts tomorrow
