Wifi issue - all LED blinking
Posted: Wed Jan 06, 2016 10:01 pm
by HodagReef
I need help troubleshooting my Wifi attachment. It was working and then it stopped and all the lights are blinking. I tried to the setup tool and and the attachment "sees" my router, by it does not connect to the internet. I try to update the firmware and I get an error (not able to connect to the internet). So I try you manually set up the attachment with Tera Term, but it does not connect. Any suggestions?
Re: Wifi issue - all LED blinking
Posted: Thu Jan 07, 2016 2:30 pm
by oftheangels
Using Tera Term and you ping your gateway address? If so it is communicating with your router.
-LeoD
Posted: Thu Jan 07, 2016 4:08 pm
by HodagReef
LeoD, When I attach USB cable - Wifi attachment and I enter $$$ to start to confr with Tera Term program, nothing happens, just a blank screen.
Troy
Posted: Thu Jan 07, 2016 8:07 pm
by oftheangels
Unfortunately I am on a Mac... However, in my experience this happens if the baud rate is not set properly in Terra Term? What is your baud rate set at (in Terra Term)? The two that work for me are 9600 (the firmware default) or 57600. Have you tried both of these baud rates?
-LeoD
Posted: Thu Jan 07, 2016 10:16 pm
by HodagReef
I was able to use Tera Term to set my baud rate at 57600 and follow the rest of the Wifi manual set-up, but all my LED are flashing.
So I try the utility set again some maybe to note: when I look at my code my SSid=WiFly-GSX-4a??? This is not what I enter? I believe it is the RA Wifi attachment SSid.
Anybody have suggestion what else to do or is my attachment not working.
Posted: Fri Jan 08, 2016 6:06 am
by oftheangels
Can you connect with terra term, enter command mode and post the results of 'get everything'. I can take a look and see if I can help.
-LeoD
Posted: Fri Jan 08, 2016 10:46 am
by HodagReef
Thanks LeoD, I was able to connect last night. Just need to have the cable connect before opening the program. I will send a copy of 'get everthing' when I get home later tonight.
Posted: Fri Jan 08, 2016 7:39 pm
by HodagReef
I tried the Wifi setup again this is the code I get (many errors):
Verifying speed at 9600 baud
Connected to serial port COM4
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
Removing connection to COM4
< CMD
< reboot
> reboot
Wifi Attachment Connected to COM4
Opening Serial Port...
< CMD
< ls
> ls
< FL# SIZ FLAGS
< 2 79680 3 WiFly_GSX-2.36
< 22 1052 10 config
< 23 1052 10 user
< 24 88548 3 wifly-GSX-441-r1057
< 25 88548 3 wifly-GSX-441-r1057
< 34 83648 3 WiFly_GSX-2.45
< 79 46632 3 wps_app-GSX-131
< 80 66240 3 eap_app-GSX-101
< 81 74920 3 web_app-GSX-106
< 82 37282 0 web_config.html
< 83 512 0 link.html
< 103 Free, Boot=24, Backup=25
< <4.41>
< load user
> load user
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> save
< save
< Storing in config
< <4.41>
> set o d ReefAngelWifi
< set o d ReefAngelWifi
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s Moe's$Tavern
< set w s Moe's$Tavern
< AOK
< <4.41>
> set w p trojen8920
< set w p trojen8920
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=Moe's Tavern
< Chan=11
< Assoc=OK
< Rate=12, 24Mb
< Auth=OK
< Mode=MIXED
< DHCP=OK,renew=64796
< Boot=2044
< Time=FAIL
< Links=1
< <4.41>
> get i
< get i
< IF=UP
< DHCP=ON
< IP=192.168.1.162:2000
< NM=255.255.255.0
< GW=192.168.1.1
< HOST=198.171.134.6:80
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.41>
> reboot
< reboot
Found router WRT1900ACS
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 22 1052 10 config
< 23 1052 10 user
> load user
< <4.41>
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> save
< save
< Storing in config
< <4.41>
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
< AOK
< <4.41>
> set w p trojen8920
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=Moe's Tavern
< Chan=11
< Assoc=OK
< Rate=12, 24Mb
< Auth=OK
< Mode=MIXED
< Boot=2046
< Time=FAIL
< Links=1
< <4.41>
> get i
< get i
< IF=UP
< DHCP=ON
< NM=255.255.255.0
< GW=192.168.1.1
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.41>
> reboot
< reboot
< CMD
< ftp u
> ftp u
< <4.41>
< FTP connecting to 198.175.253.161
< FTP file=25:................................................................
< UPDATE OK
< FTP OK.
> ftp r wps.img
< ftp r wps.img
< <4.41>
< 550 wps.img: The system cannot find the file specified.
< FTP ERR
Click on button "Connect"
> set u b 57600
> set s p 0
> save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
< reboot
> reboot
< CMD
> factory RESET
< factory RESET
< Set Factory Defaults
> reboot
< <4.41>
< reboot
Factory Settings Restored
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ftp u
< ftp u
< <4.41>
< FTP file=24:................................................................
< UPDATE OK
< FTP OK.
> ftp r wps.img
< ftp r wps.img
< <4.41>
< FTP ERR
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
< ls
> ls
< FL# SIZ FLAGS
< 22 1052 10 config
< 23 1052 10 user
> load user
< <4.41>
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
< save
> save
< Storing in config
< <4.41>
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s ____________
< set w s ___________
< AOK
< <4.41>
> set w p ___________
< set w p __________
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=__________
< Chan=11
< Assoc=OK
< Rate=12, 24Mb
< Auth=OK
< Mode=MIXED
< Boot=2043
< Time=FAIL
< Links=1
< <4.41>
> get i
< get i
< IF=UP
< DHCP=ON
< NM=255.255.255.0
< GW=192.168.1.1
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.41>
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 22 1052 10 config
< 23 1052 10 user
< <4.41>
> load user
< load user
< AOK
< <4.41>
< save
> save
< Storing in config
< <4.41>
> save
< save
< Storing in config
< <4.41>
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s _____________
< set w s _____________
< AOK
< <4.41>
> set w p XXXXXXXXX
< set w p XXXXXXXXX
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=XXX'X XXXXXX
< Chan=11
< Assoc=OK
< Rate=12, 24Mb
< Auth=OK
< Mode=MIXED
< Boot=2043
< Time=FAIL
< Links=1
< <4.41>
> get i
< get i
< IF=UP
< DHCP=ON
< NM=255.255.255.0
< GW=192.168.1.1
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.41>
> reboot
< reboot
Posted: Fri Jan 08, 2016 9:05 pm
I don't think it works with a space nor the apostrophe. Try using a ssid without them
Posted: Fri Jan 08, 2016 9:13 pm
by oftheangels
I was wondering the same about the apostrophe. Also it looks like you updated the firmware when you did ftp u... If so you will need to run the script in this thread http://forum.reefangel.com/viewtopic.php?f=3&t=4601
-LeoD
Posted: Sat Jan 09, 2016 4:52 pm
by HodagReef
Ok I removed the ' in the SSID and ran the Macro fix in Tera Term; but the lights are blinking blue. Here is the code Marco that was config to my Wifi:
CMD
factory RESET
<4.41> reboot
*Reboot*CMD
AOK
<4.41> save
Storing in config
<4.41> set wlan ssid Moes Tavern
AOK
<4.41> set wlan pass ____Hiden__
AOK
AOK
<4.41> set w j 1
AOK
<4.41> set c c 0
AOK
<4.41> set c r 0
AOK
<4.41> set c o 0
AOK
<4.41> set i d 1
AOK
<4.41> set c i 3
AOK
<4.41> set dns name www.reefangel.com
AOK
<4.41> set i h 198.171.134.6
AOK
<4.41> set i r 80
AOK
<4.41> set i f 0x06
AOK
<4.41> set s t 0x10
AOK
<4.41> set u m 2
AOK
<4.41> set i p 2
AOK
<4.41> set u b 57600
AOK
<4.41> set s p 0
AOK
<4.41> set c s 1420
AOK
<4.41> save
Storing in config
<4.41> save user
Storing in user
<4.41> reboot
*Reboot*
Any thoughts? Should I run Wifi utility? I thought you run the macro, you don't need to use the wifi utility anymore. It should be already configured.
Troy
Posted: Sat Jan 09, 2016 5:25 pm
by HodagReef
So I did the config with the wifi utility tool and the lights is just blinking green. Here is the code:
> set u b 57600
> set s p 0
> save
> reboot
> set u b 57600
> set s p 0
> save
> reboot
< CMD
> reboot
< reboot
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 22 1052 10 config
< 23 1052 10 user
< <4.41>
> load user
< load user
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> save
< save
< Storing in config
< <4.41>
< AOK
< <4.41>
> set w l 5
< set w l 5
< AOK
< <4.41>
> set w s Moes$Tavern
< set w s Moes$Tavern
< AOK
< <4.41>
> set w p ____hiden___
< set w p _____hiden__
< AOK
< <4.41>
< AOK
< <4.41>
< AOK
< <4.41>
> save
< save
< Storing in config
< <4.41>
> reboot
< reboot
< CMD
> show n
< show n
< SSid=Moes Tavern
< Chan=11
< Assoc=OK
< Rate=12, 24Mb
< Auth=OK
< Mode=MIXED
< Boot=2045
< Time=FAIL
< Links=1
< <4.41>
> get i
< get i
< IF=UP
< DHCP=ON
< NM=255.255.255.0
< GW=192.168.1.1
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <4.41>
> reboot
< reboot
Posted: Sat Jan 09, 2016 6:04 pm
Blinking green is good. It means it is connected to your wifi.
