Power box usb
tyson_mitchell_88
Power box usb
Post by tyson_mitchell_88 »
I currently have 2 power boards and am wondering if I can use the usb on both of them. Was using an expansion hub, but I think it is causing bus lock errors, and would like to plug my PWM expansion into board two.
It doesn't seem to work off the bat and am wondering if anything would need to be changed script wise.
#include <Moon.h>
//Standard Dimming//
byte ActinicPWMValue=0;    // For cloud code
byte DaylightPWMValue=0;   // For cloud code
//Dimmer Expansion//
byte WhitePWMValue=0;
byte SupPWMValue=0;
byte MoonPWMValue=0;
    ReefAngel.AddSalinityExpansion();  // Salinity Expansion Module
    ReefAngel.AddORPExpansion();  // ORP Expansion Module
    ReefAngel.FeedingModePortsE[0] = Port7Bit | Port8Bit;
    ReefAngel.Relay.On(Port1);
    ReefAngel.Relay.On(Port6);
    ReefAngel.StandardHeater( Port2,220,225 );
    ReefAngel.StandardLights( Port3,8,00,16,00);
    ReefAngel.StandardFan   ( Port4,230,238 );
    ReefAngel.StandardLights( Port7,21,00,5,00 );
    ReefAngel.StandardLights( Port8,5,00,21,00 );
    ReefAngel.StandardLights( Box1_Port5,8,00,16,00 );
//Display in Failsafe//
      ReefAngel.Relay.Off(Box1_Port8);
//boosterpump//
      ReefAngel.Relay.Off(Box1_Port2);
//Lighting Control//
    ActinicPWMValue=PWMSlope(5,00,21,00,11,100,180,ActinicPWMValue);
    DaylightPWMValue=PWMSlope(6,30,18,30,0,70,180,DaylightPWMValue);
    WhitePWMValue=PWMSlope(6,30,18,30,0,60,180,WhitePWMValue);
    SupPWMValue=PWMSlope(8,00,16,00,0,80,200,SupPWMValue);
    MoonPWMValue=PWMSlope(21,00,5,00,0,30,235,0);
    CheckCloud();
//Lighting expansion control//
    ReefAngel.PWM.SetChannel( 0, WhitePWMValue);
    ReefAngel.PWM.SetChannel( 1, ActinicPWMValue);
    ReefAngel.PWM.SetChannel( 2, SupPWMValue);
    ReefAngel.PWM.SetChannel( 3, SupPWMValue);
    ReefAngel.PWM.SetChannel( 4, MoonPWMValue);
    ReefAngel.PWM.SetChannel( 5, MoonPWMValue);
//Waterchange Mode
  static byte wc_start=false;
  static time_t wc_drain=0;
  static time_t wc_refill=0;
  if ((ReefAngel.DisplayedMenu==WATERCHANGE_MODE || (hour()==18 && minute()==0)) && !wc_start) {   // At 6pm every day the following to occur or when WC mode is activated
    wc_start==true;
    wc_drain=now()+600;
  if (wc_start) {
    // box1 port 7 & 8 to turn off
    ReefAngel.Relay.Off(Box1_Port7);
    if (now() < wc_drain || !ReefAngel.HighATO.IsActive()) {  // Activate box 1 port 4, until ato high is off, for 10 minutes (Sump out)
    } else if (now() < wc_refill || ReefAngel.HighATO.IsActive()) { // run box 1 port 1 until ato high is on for 10 mins (Salt In)
      ReefAngel.Relay.Off(Box1_Port4);
      // turn on box 1 port 7 & 8
    } else { // return to usual
      wc_start=false;
      ReefAngel.Relay.Off(Box1_Port1);
    ReefAngel.Portal( "tyson_mitchell_88" );
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 20
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 10
#define Start_Cloud_After NumMins(6,30)
#define Lightning_Change_per_Cloud 60
  // Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen results could happen.
    // Add Random Lightning modes
  // Example:  { Slow, Fast, Mega, Mega2 } to randomize all four modes.
  byte LightningModes[] = { Calm, Calm, Calm, Slow, Slow, Slow, Slow, Slow, Mega, Mega2 };
   static byte cloudchance=255;
  static byte cloudduration=0;
  static int cloudstart=0;
  static byte numclouds=0;
  static byte cloudindex=0;
  static int LastNumMins=0;
  static byte lightningMode=0;
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
  if (cloudchance)
    //is it time for cloud yet?
      WhitePWMValue=DaylightPWMValue;
      MoonPWMValue=DaylightPWMValue;
      if (chooseLightning)
        chooseLightning=false;
      switch (lightningMode)
      case Calm:
        break;
      case Mega:
          // Send the trigger
          Strike();
        break;
      case Mega2:
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
          else lightningstatus=0;
          if (lightningstatus)
            DaylightPWMValue=100;
            DaylightPWMValue=0;
          delay(1);
        break;
      default:
        break;
      cloudindex++;
      if (cloudindex < numclouds)
      int x=0;
      else x=17;
      ReefAngel.CustomVar[3]=cloudstart/60;    // Write the hour of the next cloud to custom variable for Portal reporting
      else x=35;
      ReefAngel.CustomVar[4]=cloudstart%60;    // Write the minute of the next cloud to custom variable for Portal reporting
    ReefAngel.CustomVar[7]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
    if (lightningchance)
      int x=0;
      else x=57;
      ReefAngel.CustomVar[5]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
      else x=75;
      ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));    // Write the minute of the next lightning to a custom variable for the Portal
void Strike()
  byte n;
  int newdata;
  byte a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
  for (byte i=0; i<a; i++)
    // Flash on
    analogWrite(daylightPWMPin,255);    // Flash on daylight port
    newdata=4095;
    Wire.beginTransmission(0x40);      // Address of the dimming expansion module
    Wire.write(0x8+(4*0));             // 0x8 is channel 0, 0x12 is channel 1, etc.  I'm using channel 0.
    Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
    Wire.write(newdata>>8);            // This sends the MSB
    Wire.endTransmission();
    // Flash off.  Return to baseline.
    analogWrite(daylightPWMPin,DaylightPWMValue*2.55);      // Flash off
    newdata=ReefAngel.PWM.GetChannelValue(0);   // Use the channel number you're flashing here
    Wire.beginTransmission(0x40);    // Same as above
    Wire.write(0x8+(4*1));
    wdt_reset();    // Reset watchdog timer to avoid re-boots
  cstart*=60;
  cend*=60;
Re: Power box usb
The expansion port on the second relay box will not work.
