PWM dimming using standard lights & low ATO - seeking advice
Posted: Tue Jan 19, 2016 2:19 am
Hi guys,
I would really appreciate it if one of the gurus on this forum could take a look at my code and see if makes sense and whether there's anything wrong/missing...
Context - Additional features
* I want to control and dim 3 strings of LED lights with my RA+, using the standard Actinic and Daylight ports as well as the Low ATO port. My LED strings are:
1) Meanwell LDD 5 volt [using Actinic port]
2) Meanwell LDD 5 volt [using Daylight port]
3) Meanwell ELN-P 10 volt [using LowATO port]
* I also want to control the fan on my light unit via Temperature probe 1, where the fan will be plugged into port 8 and activated when the Temp probe reads a temperature of, say 40 degree Celsius. I have not yet added this into the code...
* Also, I would like to add the lightning and cloud features such as those amazing ones added to this forum
* And then, finally, I would like a really graphic (screen) to show the current lighting status/percentage per channel (for e.g. rename the LowATO port to "XMLs" so that it will display on the RA screen as "XML: 20%", or something like that! I have not yet added this into the code...
I'm not currently using expansion modules or WiFi (yet!).
Here is the code I came up with so far:
InternalMemory.OverheatTemp_write( 30 );
ReefAngel.Relay.On( Port7 );
pinMode(lowATOPin,OUTPUT);
analogWrite(lowATOPin,PWMSlope(8,0,18,0,5,50,60,5));
ReefAngel.SingleATO( false,Port2,360,0 );
ReefAngel.DosingPumpRepeat( Port3,0,60,20 );
ReefAngel.DosingPumpRepeat( Port4,0,240,10 );
ReefAngel.DosingPumpRepeat( Port5,0,300,10 );
ReefAngel.Wavemaker( Port6,60 );
ReefAngel.PWM.SetDaylight( PWMSlope(8,0,18,0,5,50,60,5) );
ReefAngel.PWM.SetActinic( PWMSlope(5,0,19,30,5,60,30,5) );
Thank so much guys.
Thank so much guys.
