What heater do you like?
Posted: Tue Feb 02, 2016 2:46 pm
by paperdesk
What heater(s) do you like to use with your Reef angel controller?
I've gone through a few, and haven't found any I'm really excited about.
Ted
Re: What heater do you like?
Posted: Tue Feb 02, 2016 2:53 pm
by Lionfan
I always use Finnex titanium tubes on my tank.
Posted: Tue Feb 02, 2016 3:06 pm
+1 finnex titanium. -100 via aqua titaniums (they reset to 78 degrees on power reset and also were a degree off)
Posted: Tue Feb 02, 2016 5:16 pm
by paperdesk
Do you use the TH-S series? It looks like there is also a TH and an HMS series.
Ted
Posted: Wed Feb 03, 2016 5:28 am
by cosmith71
No problems with the Finnex. You just need the tube, not one with any sort of temp control.
Posted: Wed Feb 03, 2016 6:30 am
I use the one with the temp controller. It's good backup to have a second thermostat
Posted: Wed Feb 03, 2016 8:20 am
by paperdesk
True, I almost cooked my tank once when the temp probe got pulled out of the water! I was thinking about adding a second temp probe.
Posted: Wed Feb 03, 2016 9:28 am
Second temp probe is fine but a bus lock could prevent communication to the relay box and no matter how many probes you have would still not be able to shut off the port.
Posted: Wed Feb 03, 2016 11:22 am
by paperdesk
Yes, that makes a lot of sense, good plan.
