PH unstable
Posted: Sat Feb 06, 2016 9:37 pm
by Lionfan
My pH seems to be really unstable.
Even in a glass of tank water it will stay at 2.02.
When I go into the pH calibration, it gives me a 0 for the reading. And then sometimes it will bounce back to 8.23 (Normal tank pH)
New probe and relatively new RA plus.
Re: PH unstable
Posted: Sun Feb 07, 2016 4:03 pm
If pH readings are showing zero when calibrating, there is something wrong. It should never be zero.
I have seen it before when a defective temp probe was causing ph readings to show zero when calibrating.
Can you check is this is your case too?
Re: PH unstable
Posted: Sun Feb 07, 2016 9:16 pm
by Lionfan
rimai wrote:If pH readings are showing zero when calibrating, there is something wrong. It should never be zero.
Good idea. I will definitely check temp probes.
Re: PH unstable
Posted: Sun Feb 07, 2016 9:33 pm
by Lionfan
I unplugged everything from the head unit, except for the power supply and waited for about 10 minutes, nothing changed.
Re: PH unstable
Posted: Tue Feb 09, 2016 6:06 pm
Humm. Not sure what is going on then.
If you short out the inner pin to the otter shell on the pH connector in the head unit, what happens?
Re: PH unstable
Posted: Wed Feb 10, 2016 8:46 pm
by Lionfan
rimai wrote:Humm. Not sure what is going on then.
Not sure what you mean?
Re: PH unstable
Posted: Wed Feb 10, 2016 10:05 pm
use a paper clip or small wire to short out the inner pin to the outer shell of the BNC connector in the head unit.
Re: PH unstable
Posted: Thu Feb 11, 2016 6:43 am
by Lionfan
rimai wrote:use a paper clip or small wire to short out the inner pin to the outer shell of the BNC connector in the head unit.
Will do. What am I looking for?
Re: PH unstable
Posted: Thu Feb 11, 2016 9:43 am
What pH do you get?
What calibration number do you get?
Is it still zero?
Re: PH unstable
Posted: Thu Feb 11, 2016 9:56 pm
by Lionfan
rimai wrote:What pH do you get?
Is it still zero?
PH went up to about 8, and the calibration number went up to about 550
Re: PH unstable
Posted: Thu Feb 11, 2016 10:12 pm
It seems the board is fine. It should be around 550.
Not so sure why you are getting wrong results with the probe.
Re: PH unstable
Posted: Fri Feb 12, 2016 7:56 am
by Lionfan
rimai wrote:It seems the board is fine. It should be around 550.
Ive switched between 3 probes I have, all new. Is there a chance some stray voltage has zapped all 3? One is a BRS lab grade
