Moonlight's with Dimming Module
oftheangels
Post by oftheangels »
I'm having a bit of an issue with my moonlight's. I have a Dimming module that connects to an I/O expansion module that is connected directly to the RA+. The moonlight's are staying on throughout the day even though I explicitly try and turn them off. My code is below:
void setMoon()
#ifdef debug_lights == 1
  Serial.print("Daylight: ");
  Serial.print(sunLocation.IsDaytime());
  Serial.print(" MoonPhase: ");
  Serial.print(MoonPhase());
  Serial.println();
#endif
  if (sunLocation.IsDaytime())
    ReefAngel.PWM.SetChannel(0, 0);
    ReefAngel.PWM.SetChannel( 0, MoonPhase() );
By using the serial port monitor I can see that it is daytime. I would expect setting the channel to 0 should turn it off.
Any advice on an alternative? Thanks in advance.
-LeoD
Re: Moonlight's with Dimming Module
Maybe its getting set elsewhere? Code looks fine...
oftheangels
Thanks for the response... That is the only place that channel 0 is getting set in my code. Is it possible I need to reboot my RA? BTW) Is there a way to do a reboot that does not require unplugging it?
If you have wireless you can do /boot to bounce it.
