I mean I'm an IT guy, so I can just take a random machine I have and plug it in and leave it, to RDP to it...
Buuuut, ya, wondered if this was going to be added.
*edit
I take that back, in reflection, the question should be, *can I program the outlets over the web?
I see the 'internal memory' section on the portal, and the dosing pump tab, but I believe I set up my doser by the timing of the outlet.
Can I adjust this time? Or are relay times and dosing pump stats completely different? (I assume the dosing pump stats are RA dosers?)
