Dimming expansion issue
Posted: Thu Feb 18, 2016 3:08 am
Idk If channel 4 worked or not befor a diy jabeo harness but I set jumpers to 5v anolog and only seeing 0.53 volts at 100% undid jumpers and maybe got 0.56v not sure might been the same. I did have a backwards wire on the pump side of the harness the ground and 5v signal was swapped or maybe while testing with multi meter could have shorted the probe across 2 of 3 wires not 100%sure.
What can I test on the expansion board to see if I popped something?
