Is there any type of debug output or message
Posted: Mon Feb 29, 2016 11:12 pm
Hi - odd question, but is there any way to get debug information or test the code before it is uploaded to the controller?
I've been trying to modify the cloud feature to ramp up my RW4 power heads to full blast when the lightning strikes. However, I'm not seeing anything happen and I've had 2 storms today
I'm also trying to see if I have my code correct with regards to random power head changes (using some of the examples here on the boards).
Disconnecting my wifi to connect the cable and upload, test, then disconnect and reconnect wifi to see portal patterns is getting old. I'm just wondering if there is an easier way or way to debug/test so I can see the values and logic flow say as if I was coding on my Linux server
Or, is this just an experience thing or limitation to the arduino system.
