- Feeding Mode
- Water Change Mode
- Overheat Shutoff Mode - triggered when the overheat temperature is met or exceeded
- Lights On Mode - triggered when Lights On menu item is selected (built in to Main menu, not in Simple menu or Custom menu (unless you add it in manually))
- Feeding - Ports 8, 6, 5
- Water Change - Ports 8, 6, 5
- Overheat Shutoff - Ports 3
- Lights On - Ports 3, 2
These are set inside your PDE/INO file. There are 2 ways to change these ports.
1. Through the wizard. The wizard will prompt you for this and do it all for you.
2. Manually add to your PDE/INO file. This is done as follows:
// Set the ports that get toggled on & off during the following modes
// To enable a port to be toggled, place a 1 in the appropriate position
// Uncomment and update as needed
// Port 87654321
//ReefAngel.FeedingModePorts = B10110000;
//ReefAngel.WaterChangePorts = B10110000;
//ReefAngel.OverheatShutoffPorts = B00000100;
//ReefAngel.LightsOnPorts = B00000110;
// Rest of code goes here ....
If you are running 0.9.0 or later libraries, you can still use the above mentioned way OR you can use an easier to read way:
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit;
Doing it this way is a little easier to read and edit. Both ways accomplish the same thing.
For those who have an expansion relay, you must edit your PDE/INO file manually (like option 2 above). Going along with the example above, you need to add the following to the setup for the expansion relays.
// Port 87654321
ReefAngel.FeedingModePortsE[x] = B00000000;
ReefAngel.WaterChangePortsE[x] = B00000000;
ReefAngel.OverheatShutoffPortsE[x] = B00000000;
ReefAngel.LightsOnPortsE[x] = B00000000;
0 - Expansion Relay 1
1 - Expansion Relay 2
2 - Expansion Relay 3
3 - Expansion Relay 4
4 - Expansion Relay 5
5 - Expansion Relay 6
6 - Expansion Relay 7
7 - Expansion Relay 8
Going off of that index example, here are some code examples:
// Expansion Relay 1
// Port 87654321
ReefAngel.FeedingModePortsE[0] = B00000000;
ReefAngel.WaterChangePortsE[0] = B00000000;
ReefAngel.OverheatShutoffPortsE[0] = B00000000;
ReefAngel.LightsOnPortsE[0] = B00000000;
// Expansion Relay 2
// Port 87654321
ReefAngel.FeedingModePortsE[1] = B00000000;
ReefAngel.WaterChangePortsE[1] = B00000000;
ReefAngel.OverheatShutoffPortsE[1] = B00000000;
ReefAngel.LightsOnPortsE[1] = B00000000;
Once added to your PDE/INO file, you upload the file to the controller and now your controller will toggle those ports ON/OFF when you enter the modes.
