Sunlocation?
Posted: Sun Apr 10, 2016 6:36 am
by cosmith71
Can someone explain a basic implementation of sunlocation?
Re: Sunlocation?
Posted: Sun Apr 10, 2016 9:10 am
Here is the excerpt from my code that references SunLocation. I think it's pretty self explanatory. One thing to keep in mind is that if sun.UseMemory==true, which is the default, then it will write the Daylight on/off times each day.
$ egrep -i 'SunLocation|sun\.' Wizard65.ino
#include <SunLocation.h>
SunLocation sun;
sun.Init(InternalMemory.read_int(Mem_I_Latitude), InternalMemory.read_int(Mem_I_Longitude));
sun.SetOffset(riseOffset,(acclDay*acclRiseOffset),setOffset,(-acclDay*acclSetOffset)); // Bahamas
sun.CheckAndUpdate(); // Calculate today's Sunrise / Sunset
tide.SetSpeed(PWMSlope(sun.GetRiseHour()-1,sun.GetRiseMinute(),
sun.GetSetHour(),sun.GetSetMinute(),nightSpeed+tideMin,vtSpeed,120,nightSpeed+tideMin));
} else if (!sun.IsDaytime() && nightRF) {
if (sun.IsDaytime() && (now()+offset)%repeat==0) {
sprintf(buf, "%02d:%02d", sun.GetRiseHour(), sun.GetRiseMinute());
sprintf(buf, "%02d:%02d", sun.GetSetHour(), sun.GetSetMinute()); x+=36;
Re: Sunlocation?
Posted: Sun Apr 10, 2016 9:26 am
by cosmith71
Thanks, Lee, but I was looking for something more basic. You have a lot going on there!
Re: Sunlocation?
Posted: Sun Apr 10, 2016 5:56 pm
No, I don't. There's just a few examples.
The required ones are the include, the declaration, the init and the checkandupdate. The offset is optional, and the rest shows how I'm using it. If you don't do anything you can jsut declare a port StandardLights or use an LED function and it will use the rise/set to start/end whichever lighting you use.
Re: Sunlocation?
Posted: Tue Apr 12, 2016 9:07 pm
Colin you declare it and then you init it with the gps coordinates. Then you run CheckAndUpdate in your loop and each night it will refresh the sunrise and sunset times. You can then use those times in any function which I gave examples for. You can use SetOffset to adjust where you are and tune your viewing time. There are other functions to see if it's daytime or not and you can get the actual time_t (unsigned long) value for rise and set if you wanted to compare against now(). The default is to also set the memory for daylights so if you use memory for StandardLights() or if you use like Channel0PWMSlope() then it will get the sunrise and sunset from memory.
Re: Sunlocation?
Posted: Wed Apr 13, 2016 5:19 am
by cosmith71
OK, that helps immensely. Thanks!
Re: Sunlocation?
Posted: Wed Apr 13, 2016 6:33 am
by CaliFSU
This may be a little off topic but I just implemented SunLocation to my lighting schedule and is there a post that has an explanation of the slopes? And also what is the difference between the high res slopes and the regular slopes?
Re: Sunlocation?
Posted: Wed Apr 13, 2016 6:42 am
by cosmith71
HighRes returns values from 0 to 4095 (raw 12 bit values) and the regular returns values from 0 to 100 (as in percents).
Re: Sunlocation?
Posted: Thu Apr 14, 2016 1:50 pm
by CaliFSU
My lights don't appear to play well with the "standard" modes, they only appear to respond with the HighRes variations. Not sure if it matters, but I am connecting my lights to the external dimming expansion on analog channels.
Also, I cannot seem to get my lights to come on/off automatically from the SunLocation::StdLightsOnOff_write() function in the SunLocation.cpp file. What would I need to configure to get this going?
--UPDATE--
Silly error on my part calling the PWMParabolaHighRes function. I accidentally reversed the hours/minutes variables.
Re: Sunlocation?
Posted: Fri Apr 15, 2016 5:10 am
Can you post your code?
You should see the on/off time in The portal under Internal Memory. It would be in the first tab. Please confirm what times you have there and make sure to post your code.
Re: Sunlocation?
Posted: Tue Jun 21, 2016 7:10 am
by madweazl
Where are the sunrise/sunset times coming from? I see GPS mentioned but don't understand where the information is being pulled from in the code.
Re: Sunlocation?
Posted: Tue Jun 21, 2016 5:31 pm
When you run the Init function you set the coordinates. If you don't specify it will use GBR coordinates by default
Re: Sunlocation?
Posted: Tue Jun 21, 2016 6:04 pm
I think you have to set the GPS through the Init function.
There is a "Constructor" function for the SunLocation class, but I think the way we use it, it's never called.
Typically in C++ you use pointers and a constructor to do the following:
SunLocation *sl = new SunLocation();
Notice the * that means we're pointing to a location in memory and the new function returns the memory address of a newly created SunLocation class. Since we're a bit more basic, we never actually run a constructor when you do this:
So with that you'd have to run the Init in order to set the coordinates. I may modify the class to have an Init() with no args so you can use the defaults.
For the record the code is in Libraries/SunLocation and you can see in SunLocation.cpp the first two functions, the first being the constructor I mentioned and the second being the Init function.
Re: Sunlocation?
Posted: Tue Jun 21, 2016 6:24 pm
by madweazl
lnevo wrote:When you run the Init function you set the coordinates. If you don't specify it will use GBR coordinates by default
I see reference to Great Barrier Reef in there but nothing else; is that just a reference? I dont have any issues using that lat/long, I was just curious. I'm not even going to try and make sense out of the moon library yet; that one left me googly eyed.
Re: Sunlocation?
Posted: Tue Jun 21, 2016 7:44 pm
Yeah I'd say for now it only works as a reference
but yes feel free to use those with the Init function with those values.
Re: Sunlocation?
Posted: Sun Jun 26, 2016 5:49 am
by madweazl
lnevo wrote:Here is the excerpt from my code that references SunLocation. I think it's pretty self explanatory. One thing to keep in mind is that if sun.UseMemory==true, which is the default, then it will write the Daylight on/off times each day.
SunLocation sun;
I'd like to get this going but my lights dont dim to 0 (SBReef basic black boxes) so I use relays 5 and 6 for on/off functionality. Is there a way to tie that in so the relay and rise/set functions work together?
Re: Sunlocation?
Posted: Sun Jun 26, 2016 6:03 am
Yes, what I do is if my dim % is >= the percent they go off, the. i turn the relay on. Otherwise they are off.
Re: Sunlocation?
Posted: Sun Jun 26, 2016 6:05 am
The other thing you can do is set the start and end percentage to be when your lights go off. This way you get the full photoperiod.
