Temp Overheat
Posted: Mon Apr 18, 2016 11:58 am
by Ismaclst
I came home today to see that my controller was in fault because it went into temp overheat. This is the second time this has done this in the past couple weeks. I cleared the fault and the port came back on like it should. I checked the web chart to see when it overheated but at the supposed time it did it was not over my overheat temp. My overheat temp is 80 and the hottest it went was 78.6. What could be the issue?
Re: Temp Overheat
Posted: Mon Apr 18, 2016 12:06 pm
by Ismaclst
I also have an ongoing problem with my ph. The first ph probe that I used worked for a short time then it was reading low, like around 4. Then it went all the way down to 1, so I thought it was bad and replaced it. The second worked fine for about two weeks until it started to do the same as the first. It's not a voltage leak because I placed it in a separate glass of water and it still read 1.
Re: Temp Overheat
Posted: Tue Apr 19, 2016 10:02 am
by Ismaclst
Anyone?
Re: Temp Overheat
Posted: Tue Apr 19, 2016 10:08 am
Could it be the temp probe?
Re: Temp Overheat
Posted: Tue Apr 19, 2016 12:50 pm
by Ismaclst
Could be. Would a bad temp probe affect the pH probe? It appears to work right all the time.
Re: Temp Overheat
Posted: Wed Apr 20, 2016 2:56 am
by Ismaclst
It went into overheat again early this morning. Now I'm at work and can't clear the fault...
Re: Temp Overheat
Posted: Wed Apr 20, 2016 3:06 am
by cosmith71
Do you have the Android app? You can clear it from there.
Re: Temp Overheat
Posted: Wed Apr 20, 2016 4:24 am
by Ismaclst
I do but my port forwarding is not working. I had it set up once but for some reason it doesn't work anymore.
Re: Temp Overheat
Posted: Thu Apr 21, 2016 12:55 am
by Ismaclst
Checked to see if it was faulted this morning and it was. This problem is becoming more frequent. Any other ideas what could be causing this?
Re: Temp Overheat
Posted: Thu Apr 21, 2016 2:05 pm
I would start with changing the temp probe. Make sure all connections are tight. See if jiggling the connecters causes any issues
Re: Temp Overheat
Posted: Thu Apr 21, 2016 4:30 pm
by Ismaclst
I did replace the temp probe early this morning, so we will see if that helps. I checked the connections and all seems fine. I still don't understand what is going on with my PH probe. Right now it is reading 5.3. Later it will drop down to 1 them back up again. The only time it read right was when I first calibrated it. Now it never gets higher then in the fives.
Re: Temp Overheat
Posted: Thu Apr 21, 2016 4:40 pm
Probe is either getting stray voltage or its shot. How old is the probe?
Re: Temp Overheat
Posted: Thu Apr 21, 2016 5:29 pm
by Ismaclst
I placed the probe in a glass of water and it didn't change. It's maybe a month old.
Re: Temp Overheat
Posted: Thu Apr 21, 2016 6:21 pm
Do you recall the numbers you got from the calibration?
Re: Temp Overheat
Posted: Fri Apr 22, 2016 1:09 am
by Ismaclst
Not off hand. I can recalibrate to see.
Re: Temp Overheat
Posted: Fri Apr 22, 2016 2:28 pm
by Ismaclst
Here are the numbers i got when I recalibrated the probe. pH 7 was 344 and pH 10 was 575.
Re: Temp Overheat
Posted: Fri Apr 22, 2016 3:02 pm
Did it work after you calibrated?
Re: Temp Overheat
Posted: Fri Apr 22, 2016 3:16 pm
by Ismaclst
Yes, it did. The first time I calibrated it, it acted the same way. It took about a month or so then it started to drop until it reached one. Could it be that it's just a cheap pH probe?
Re: Temp Overheat
Posted: Fri Apr 22, 2016 3:17 pm
I mean right now that you just calibrated
Re: Temp Overheat
Posted: Fri Apr 22, 2016 4:25 pm
by Ismaclst
At the moment, yes. But it's already going down. It staarted at 7.47 and now it's 6.99 and dropping.
Re: Temp Overheat
Posted: Fri Apr 22, 2016 5:08 pm
Sounds shot to me
Re: Temp Overheat
Posted: Fri Apr 22, 2016 5:56 pm
by Ismaclst
I guess it's what I get for buying a real inexpensive probe.
