Page 1 of 3
New IDE v1.6.8
Posted: Sat Apr 30, 2016 10:09 pm
Hi Guys,
For anyone that would like to try out the new IDE, please download it at:
Windows: https://www.dropbox.com/s/mrpor1261zln9 ... v.exe?dl=0
MacOSX: https://www.dropbox.com/s/zyohe8hbgxbhv ... v.dmg?dl=0
It contains the latest dev libraries.
Some of the improvements:
* Libraries manager
* Line numbers
* Collapsible brackets
* Serial monitor stays open when uploading codes
Changes to the libraries were required to comply with the new gcc-avr compiler version.
The most important are:
* progr_char is now char
* prog_uchar is now unsigned char
* if you used custom menu, you will need to make these changes:
1. Declare the menu options like this:
const char menu0_label[] PROGMEM = "Feeding Mode";
2. Initialize the menu like this:
  for (int a=0;a<SIZE(menu_items);a++)
    ReefAngel.InitMenu(pgm_read_word(&(menu_items[a])),a);
Please let me know if you encounter any problems and if I missed anything.
Re: New IDE v1.6.8
Posted: Sun May 01, 2016 5:27 am
by cosmith71
So far so good. Only hiccup was with Windows and my Avast virus protection which messed up the first attempt at installation. Had to uninstall then re-install. Works great after that. I love the folding feature (collapsible brackets) and the line numbers.
You will need to update the libraries before you can compile anything.
Re: New IDE v1.6.8
Posted: Wed May 04, 2016 2:36 am
by dansonamission
When I try and run the wizard or restore default code for example, I see errors like this.
Exception in thread "AWT-EventQueue-0" java.lang.NoSuchMethodError: processing.app.Base.getSketchbookFolder()Ljava/io/File;
	at com.reefangel.tool.Wizard$WizardPreferences.<clinit>(Unknown Source)
	at com.reefangel.tool.Wizard.run(Unknown Source)
	at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:756)
	at java.awt.EventQueue.access$500(EventQueue.java:97)
	at java.awt.EventQueue$3.run(EventQueue.java:709)
	at java.awt.EventQueue$3.run(EventQueue.java:703)
	at java.security.AccessController.doPrivileged(Native Method)
	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76)
	at java.awt.EventQueue.dispatchEvent(EventQueue.java:726)
	at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
	at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
	at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
	at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Re: New IDE v1.6.8
Posted: Wed May 04, 2016 2:44 am
by cosmith71
I get the same. Also happens with "Libraries Version"
Re: New IDE v1.6.8
Posted: Wed May 04, 2016 4:09 am
by dansonamission
Have any of the included libraries been updated for 1.6.8?
Nothing will compile, started correcting the libraries but once you've fixed one, another throws multiple errors.
Re: New IDE v1.6.8
Posted: Wed May 04, 2016 10:51 am
Sorry. I forgot to send the new wizard and other tools too with the installation package.
Re: New IDE v1.6.8
Posted: Wed May 04, 2016 10:52 am
dansonamission wrote:Have any of the included libraries been updated for 1.6.8?
This installation package should contain the latest dev branch that compiles with the new ide.
Re: New IDE v1.6.8
Posted: Wed May 04, 2016 10:57 am
by dansonamission
rimai wrote:Sorry. I forgot to send the new wizard and other tools too with the installation package.
Can you please let us know when we can download an update which includes the tools etc.
There were a few library files i had to update.
* progr_char to char
* prog_uchar to unsigned char
Re: New IDE v1.6.8
Posted: Mon May 09, 2016 4:15 pm
by cosmith71
Edit: Looks like something changed in Avast antivirus. I added RA to the exclusion list and it's working again.
So not sure why, but on both my PC's, today it took FOREVER to compile. I thought it was locking up at first. i5 and an i7. They're normally pretty speedy. I tried re-installing on my i7 desktop, but ended up getting some weird error so I went back to the production version.
Re: New IDE v1.6.8
Posted: Fri Jul 01, 2016 10:36 pm
Is there a MAC version yet?
Re: New IDE v1.6.8
Posted: Fri Jul 01, 2016 10:46 pm
Not yet :(
Re: New IDE v1.6.8
Posted: Wed Jul 06, 2016 10:45 pm
I just uploaded the Mac version and updated the original post with the link.
Let me know if it works for you.
Re: New IDE v1.6.8
Posted: Sat Sep 10, 2016 3:57 pm
The requested URL /download/ReefAngelInstaller_1.1.3Dev.dmg was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Re: New IDE v1.6.8
Posted: Sat Sep 10, 2016 4:01 pm
Sorry. Updated the links
Re: New IDE v1.6.8
Posted: Sat Sep 10, 2016 8:37 pm
Thanks Roberto.
Also, for anyone interesting, I'm testing out using Sublime Text as my editor. There's an arduino plugin that let's you compile/verify/upload and I'm also using a vim plugin so that I get vi like editing. Pretty excited to try that out :)
Re: New IDE v1.6.8
Posted: Sun Sep 11, 2016 3:28 am
by troylong45
On Windows Im getting sketchbook folder disappeared and wont open
Re: New IDE v1.6.8
Posted: Sun Sep 11, 2016 9:21 am
Does open at all?
Can you post screenshot of this error?
Re: New IDE v1.6.8
Posted: Sun Sep 11, 2016 4:31 pm
by troylong45
Not past the initial boot up screen . Ill try to put up a screen shot later tonight or tomorrow
Re: New IDE v1.6.8
Posted: Sun Sep 11, 2016 4:49 pm
by troylong45
Re: New IDE v1.6.8
Posted: Sun Sep 11, 2016 4:54 pm
You should not install the Arduino IDE inside the sketchbook folder.
I would recommend it installing it in the default folder it recommended during the install.
If you do want to keep it installed in that location, make sure that you update the sketchbook folder in the preferences file manually since you can't access the IDE.
The preferences file is located at C:\Users\your_name_here\AppData\Local\Arduino15
Re: New IDE v1.6.8
Posted: Sun Sep 11, 2016 6:40 pm
by troylong45
Well this is just me messing around with it. I removed every thing all together and had only the new file u put up in drop box. Maybe i need to uninstall and restart pc and install and try restart again I'll try tomorrow night agaim
Re: New IDE v1.6.8
by troylong45
Re: New IDE v1.6.8
Posted: Sun Sep 11, 2016 6:42 pm
by troylong45
I even tried installing it on the factory location of where it auto places it I'll try again tomorrow night tho
Re: New IDE v1.6.8
Posted: Mon Sep 12, 2016 5:11 am
by cosmith71
Try disabling your antivirus while installing, and add RA as an exception. It seems like I had this same problem.
Re: New IDE v1.6.8
Posted: Wed Nov 23, 2016 9:50 am
by troylong45
ok been a while since i was able to try to work on my ra. i turned off av on install i think its working now but my old code i changed the menu stuff over and i try to verify the code and i get error
Arduino:  (Reef Angel compilation) v1.6.8 (Windows 8.1), Board: "Cloud Wifi Attachment"
Watchdog Timer
Version Menu
Dimming Expansion Module
Dimming Signal
Wifi Attachment
Custom Main Screen
Custom Variable
Extra Font - Medium Size (8x8 pixels)
Extra Font - Numbers Only - Large Font (8x16 pixels)
Date/Time Setup Menu
Relay Expansion Module
Custom Menu
Moon Phase Label
DC Pump Control (Jebao/Tunze)
Number of Relay Expansion Modules: 2
Number of Menu Options: 8
In file included from C:\Users\annlong90\Documents\Arduino\libraries\Globals/Globals.h:31:0,
                 from C:\Users\annlong90\Documents\ra ino\troyraino09112016\troyraino09112016.ino:2:
C:\Users\annlong90\Documents\Arduino\libraries\OneWire/OneWire.h:108:2: error: #error "Please define I/O register types here"
In file included from C:\Users\annlong90\Documents\Arduino\libraries\Globals/Globals.h:40:0,
C:\Users\annlong90\Documents\Arduino\libraries\RA_Wifi/RA_Wifi.h:29:21: fatal error: avr/wdt.h: No such file or directory
 #include <avr/wdt.h>
compilation terminated.
exit status 1
Error compiling for board Cloud Wifi Attachment.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
my code here
    #include <SunLocation.h>
    #include <Tide.h>
    #include <Moon.h>
    #include <WiFiAlert.h>
        // Won't compile without this...
        // ReefAngel.DCPump.UseMemory=true;
        // Custom menus
        #include <avr/pgmspace.h>
        const char menu1_label[] PROGMEM = "Feeding Mode";
        const char menu2_label[] PROGMEM = "Water Change";
        const char menu3_label[] PROGMEM = "ATO Clear";
        const char menu4_label[] PROGMEM = "DC Pump Mode";
        const char menu5_label[] PROGMEM = "Overheat Clear";
        const char menu6_label[] PROGMEM = "PH Calibration";
        const char menu7_label[] PROGMEM = "Date / Time";
        const char menu8_label[] PROGMEM = "Refugium Light";
        menu4_label, menu5_label, menu6_label, menu7_label, menu8_label
        // Define Custom Memory Locations
        #define Mem_B_MoonOffset          100
        #define Mem_B_AtoHourInterval     101
        #define Mem_I_Latitude            108
        #define Mem_I_Longitude           110
        #define Mem_B_AcclRiseOffset      112
        #define Mem_B_AcclSetOffset       113
        #define Mem_B_AcclDay             114
        #define Mem_B_TideMin             117
        #define Mem_B_TideMax             118
        #define Mem_B_PumpOffset          119
        #define Mem_B_FeedingDCPump       120
        #define Mem_B_NightDCPump         121
        #define Mem_B_NightSpeed          122
        #define Mem_B_NightDuration       123
        #define Mem_B_NTMSpeed            124
        #define Mem_B_NTMDuration         125
        #define Mem_B_NTMDelay            126
        #define Mem_B_NTMTime             127
        #define Mem_B_TideMode            143
        #define Mem_B_CloudsEveryXDays    149
        #define Mem_B_CloudChancePerDay   150
        #define Mem_B_MinCloudDuration    151
        #define Mem_B_MaxCloudDuration    152
        #define Mem_B_MinCloudsPerDay     153
        #define Mem_B_MaxCloudsPerDay     154
        #define Mem_B_StartCloudAfterHour 155
        #define Mem_B_StartCloudAfterMin  156
        #define Mem_B_EndCloudBeforeHour  157
        #define Mem_B_EndCloudBeforeMin   158
        #define Mem_B_LightningChance     159
        #define Mem_B_LightMode           160
        #define Mem_B_LightOffset         161
        #define Mem_I_RiseOffset          162
        #define Mem_I_SetOffset           164
        #define Mem_B_AcclActinicOffset   166
        #define Mem_B_AcclDaylightOffset  167
        #define Mem_B_RandomMode          168
        #define Mem_B_GyreOffset          169
        #define Mem_B_MoonMode            170
        #define Mem_B_LightsOffPerc       171
        #define Mem_B_FeedingSpeed        172
        #define Mem_B_WCSpeed             173
        #define Mem_B_EnableStorm         178
        #define Mem_B_ForceRandomTide     179
        #define Mem_B_ResetMemory         199
        void init_memory() {
          // Initialize Custom Memory Locations
          InternalMemory.write(Mem_B_MoonOffset,15);           //mb100
          InternalMemory.write(Mem_B_AtoHourInterval,1);       //mb101
          InternalMemory.write_int(Mem_I_Latitude,-21);        //mi108
          InternalMemory.write_int(Mem_I_Longitude,-147);      //mi110
          InternalMemory.write(Mem_B_AcclRiseOffset,12);       //mb112
          InternalMemory.write(Mem_B_AcclSetOffset,13);        //mb113
          InternalMemory.write(Mem_B_AcclDay,0);               //mb114
          InternalMemory.write(Mem_B_TideMin,10);              //mb117
          InternalMemory.write(Mem_B_TideMax,20);              //mb118
          InternalMemory.write(Mem_B_PumpOffset,80);           //mb119
          InternalMemory.write(Mem_B_FeedingDCPump,true);      //mb120
          InternalMemory.write(Mem_B_NightDCPump,false);       //mb121
          InternalMemory.write(Mem_B_NightSpeed,35);           //mb122
          InternalMemory.write(Mem_B_NightDuration,16);        //mb123
          InternalMemory.write(Mem_B_NTMSpeed,100);            //mb124
          InternalMemory.write(Mem_B_NTMDuration,50);          //mb125
          InternalMemory.write(Mem_B_NTMDelay,5);              //mb126
          InternalMemory.write(Mem_B_NTMTime,5);               //mb127
          InternalMemory.write(Mem_B_TideMode,0);              //mb143
          InternalMemory.write(Mem_B_CloudsEveryXDays,1);      //mb149
          InternalMemory.write(Mem_B_CloudChancePerDay,50);    //mb150
          InternalMemory.write(Mem_B_MinCloudDuration,6);      //mb151
          InternalMemory.write(Mem_B_MaxCloudDuration,10);     //mb152
          InternalMemory.write(Mem_B_MinCloudsPerDay,2);       //mb153
          InternalMemory.write(Mem_B_MaxCloudsPerDay,8);       //mb154
          InternalMemory.write(Mem_B_StartCloudAfterHour,10);  //mb155
          InternalMemory.write(Mem_B_StartCloudAfterMin,00);   //mb156
          InternalMemory.write(Mem_B_EndCloudBeforeHour,22);   //mb157
          InternalMemory.write(Mem_B_EndCloudBeforeMin,00);    //mb158
          InternalMemory.write(Mem_B_LightningChance,50);      //mb159
          InternalMemory.write(Mem_B_LightMode,1);             //mb160
          InternalMemory.write(Mem_B_LightOffset,30);          //mb161
          InternalMemory.write_int(Mem_I_RiseOffset,20);       //mi162
          InternalMemory.write_int(Mem_I_SetOffset,16);        //mi164
          InternalMemory.write(Mem_B_AcclActinicOffset,250);   //mb166
          InternalMemory.write(Mem_B_AcclDaylightOffset,125);  //mb167
          InternalMemory.write(Mem_B_RandomMode,false);        //mb168
          InternalMemory.write(Mem_B_GyreOffset,10);           //mb169
          InternalMemory.write(Mem_B_MoonMode,1);              //mb170
          InternalMemory.write(Mem_B_LightsOffPerc,1);         //mb171
          InternalMemory.write(Mem_B_FeedingSpeed,0);          //mb172
          InternalMemory.write(Mem_B_WCSpeed,0);               //mb173
          InternalMemory.write(Mem_B_ResetMemory,false);       //mb199
        #define NUMBERS_8x16
        #define Var_Tide         4
        #define Var_TideMode     5
        // Define Relay Ports by Name
        #define Return             1
        #define Heater             2
        #define Refugium           3
        #define MediaPump          4
        #define WhiteLeft          5
        #define BlueLeft           6
        #define Autotopoff         7
        #define Skimmer            8
        // Custom classes
        SunLocation sun;
        Tide tide;
        // Jebao Variables
        byte DCPumpMode, DCPumpSpeed, DCPumpDuration;
        // For Cloud and preset code
        int DaylightPWMValue=0;
        int ActinicPWMValue=0;
        int DaylightPWMValue0=0;        // For cloud code, channel 0
        int DaylightPWMValue2=0;        // For cloud code, chennel 2
        int ActinicPWMValue1=0;        // For cloud code, channel 0
        int ActinicPWMValue3=0;        // For cloud code, chennel 2
        // Needs to be global for DrawCustomGraph()
        int ScreenID=1;
        // Setup on controller startup/reset
    ReefAngel.InitMenu(pgm_read_word(&(menu_items[a])),a); // Initialize Menu
          ReefAngel.FeedingModePorts = Port1Bit | Port2Bit ;
          ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port7Bit  | Port8Bit;
          ReefAngel.LightsOnPorts = Port3Bit | Port5Bit | Port6Bit;
          ReefAngel.OverheatShutoffPorts =  Port2Bit | Port4Bit;
        ReefAngel.Relay.On( Return ); // Return Pump
       randomSeed(now()/SECS_PER_DAY);
          if (InternalMemory.read(Mem_B_ResetMemory))
            init_memory();
        DelayedOnFeedMode(Return); // DelayedOn after feed mode change only
        ReefAngel.Relay.Set(Refugium,!ReefAngel.Relay.Status(WhiteLeft));
        ReefAngel.SingleATO(true,Autotopoff, InternalMemory.ATOExtendedTimeout_read(), InternalMemory.read(Mem_B_AtoHourInterval));
        ReefAngel.Relay.Set(Skimmer, ReefAngel.HighATO.IsActive());
        ReefAngel.DCPump.ExpansionChannel[4] = AntiSync; // Left Jebao RW4
        ReefAngel.DCPump.ExpansionChannel[5] = Sync; // Right jebao rw4
        ReefAngel.StandardHeater(Heater);
          // Lighting and Flow
          SetSun();               // Setup Sun rise/set lighting
          AcclimateLED();         // Apply acclimation dimming
          SetMoon();              // Setup Moon rise/set lighting
          FillInMoon();           // Fill in 5% to 0% gap in main LEDs
          LEDPresets();
          CheckCloud();           //  Check for cloud and lightning.
          UpdateLED();
          SetTide();              // Set High/Low tide properties
          SetDCPump();                // Set Vortech modes
           ReefAngel.Portal( "troylong45" );
        ReefAngel.DDNS( "1" ); // Your DDNS is troylong45-1.myreefangel.com
        void SetSun() {
          // Start acclimation routine
          int acclRiseOffset=InternalMemory.read(Mem_B_AcclRiseOffset)*60;
          int acclSetOffset=InternalMemory.read(Mem_B_AcclSetOffset)*60;
          byte acclDay=InternalMemory.read(Mem_B_AcclDay);
          // See if we are acclimating corals and decrease the countdown each day
          static boolean acclCounterReady=false;
          if (now()%SECS_PER_DAY!=0) acclCounterReady=true;
          if (now()%SECS_PER_DAY==0 && acclCounterReady && acclDay>0) {
            acclDay--;
            InternalMemory.write(Mem_B_AcclDay,acclDay);
          // End acclimation
          // Add some customizable offsets
          sun.Init(InternalMemory.read_int(Mem_I_Latitude), InternalMemory.read_int(Mem_I_Longitude));
          int riseOffset=InternalMemory.read_int(Mem_I_RiseOffset);
          int setOffset=InternalMemory.read_int(Mem_I_SetOffset);
          sun.SetOffset(riseOffset,(acclDay*acclRiseOffset),setOffset,(-acclDay*acclSetOffset)); // Bahamas
          sun.CheckAndUpdate(); // Calculate today's Sunrise / Sunset
          byte lightOffset=InternalMemory.read(Mem_B_LightOffset); // left right separation
          byte actinicOffset=InternalMemory.ActinicOffset_read();
          // Make sure light resets to zero at night.
          for(int i=0;i<4;i++) { ReefAngel.PWM.SetChannel(i,0); }
          switch(InternalMemory.read(Mem_B_LightMode)) {
            case 0: {
              // Daylights
              ReefAngel.PWM.Channel0PWMSlope(lightOffset,0);
              ReefAngel.PWM.Channel2PWMSlope(0,lightOffset);
              // Actinics
              ReefAngel.PWM.Channel1PWMSlope(actinicOffset+lightOffset,actinicOffset);
              ReefAngel.PWM.Channel3PWMSlope(actinicOffset,actinicOffset+lightOffset);
              break;
            case 1: {
              // Daylights
              ReefAngel.PWM.Channel0PWMParabola(lightOffset,0);
              ReefAngel.PWM.Channel2PWMParabola(0,lightOffset);
              // Actinics
              ReefAngel.PWM.Channel1PWMParabola(actinicOffset+lightOffset,actinicOffset);
              ReefAngel.PWM.Channel3PWMParabola(actinicOffset,actinicOffset+lightOffset);
              break;
          case 2: {
              // Daylights
              ReefAngel.PWM.Channel0PWMSmoothRamp(lightOffset,0);
              ReefAngel.PWM.Channel2PWMSmoothRamp(0,lightOffset);
              // Actinics
              ReefAngel.PWM.Channel1PWMSmoothRamp(actinicOffset+lightOffset,actinicOffset);
              ReefAngel.PWM.Channel3PWMSmoothRamp(actinicOffset,actinicOffset+lightOffset);
              break;
          case 3: {
              // Daylights
              ReefAngel.PWM.Channel0PWMSigmoid(lightOffset,0);
              ReefAngel.PWM.Channel2PWMSigmoid(0,lightOffset);
              // Actinics
              ReefAngel.PWM.Channel1PWMSigmoid(actinicOffset+lightOffset,actinicOffset);
              ReefAngel.PWM.Channel3PWMSigmoid(actinicOffset,actinicOffset+lightOffset);
              break;
          case 4: { // Reverse the actinics in the morning
          // Daylights
          ReefAngel.PWM.Channel0PWMParabola(lightOffset+actinicOffset,0);
          ReefAngel.PWM.Channel2PWMParabola(actinicOffset,lightOffset);
          // Actinics
          ReefAngel.PWM.Channel1PWMParabola(lightOffset,actinicOffset);
          ReefAngel.PWM.Channel3PWMParabola(0,actinicOffset+lightOffset);
          break;
    void SetMoon() {
      byte offset=InternalMemory.read(Mem_B_MoonOffset);
      byte startD=InternalMemory.read(Mem_B_PWMSlopeStartD);
      byte endD=InternalMemory.read(Mem_B_PWMSlopeEndD);
      byte timeD=InternalMemory.read(Mem_B_PWMSlopeDurationD);
      byte startA=InternalMemory.read(Mem_B_PWMSlopeStartA);
      byte endA=InternalMemory.read(Mem_B_PWMSlopeEndA);
      byte timeA=InternalMemory.read(Mem_B_PWMSlopeDurationA);
      time_t onTime=ScheduleTime(Moon.riseH, Moon.riseM,0);
      time_t offTime=ScheduleTime(Moon.setH, Moon.setM,0);
      time_t offsetOnTime=ScheduleTime(Moon.riseH, Moon.riseM,0)-(offset*60);
      time_t offsetOffTime=ScheduleTime(Moon.setH, Moon.setM,0)-(offset*60);
      byte actRiseH=(offsetOnTime%SECS_PER_DAY)/SECS_PER_HOUR;
      byte actRiseM=((offsetOnTime%SECS_PER_DAY)%SECS_PER_HOUR)/60;
      byte actSetH=(offsetOffTime%SECS_PER_DAY)/SECS_PER_HOUR;
      byte actSetM=((offsetOffTime%SECS_PER_DAY)%SECS_PER_HOUR)/60;
      static byte mp=MoonPhase();
      if (mp!=MoonPhase()) {
        InternalMemory.write(Mem_B_PWMSlopeEndD,mp);
        InternalMemory.write(Mem_B_PWMSlopeEndA,mp);
        mp=MoonPhase();
      moon_init(InternalMemory.read_int(Mem_I_Latitude), InternalMemory.read_int(Mem_I_Longitude));
      ReefAngel.PWM.SetDaylight(0);
      ReefAngel.PWM.SetActinic(0);
      switch(InternalMemory.read(Mem_B_MoonMode)) {
        case 0: {
          // Daylights
          ReefAngel.PWM.SetDaylightRaw(PWMSlopeHighRes(Moon.riseH,Moon.riseM,Moon.setH,Moon.setM,startA,endA,timeA,0));
          ReefAngel.PWM.SetActinicRaw(PWMSlopeHighRes(actRiseH,actRiseM,actSetH,actSetM,startD,endD,timeD,0));
          break;
        case 1: {
          ReefAngel.PWM.SetDaylightRaw(PWMParabolaHighRes(Moon.riseH,Moon.riseM,Moon.setH,Moon.setM, startA,endA,0));
          ReefAngel.PWM.SetActinicRaw(PWMParabolaHighRes(actRiseH,actRiseM,actSetH,actSetM, startD,endD,0));
          break;
      case 2: {
          ReefAngel.PWM.SetDaylightRaw(PWMSmoothRampHighRes(Moon.riseH,Moon.riseM,Moon.setH,Moon.setM,startA,endA,timeA,0));
          ReefAngel.PWM.SetActinicRaw(PWMSmoothRampHighRes(actRiseH,actRiseM,actSetH,actSetM,startD,endD,timeD,0));
          break;
      case 3: {
          ReefAngel.PWM.SetDaylightRaw(PWMSigmoidHighRes(Moon.riseH,Moon.riseM,Moon.setH,Moon.setM,startA,endA,0));
          ReefAngel.PWM.SetActinicRaw(PWMSigmoidHighRes(actRiseH,actRiseM,actSetH,actSetM,startD,endD,0));
          break;
    void FillInMoon() {
      // Extend the sunrise/sunset to fill in gaps when fixtures shut off.
      int LightsOffPerc=40.95*InternalMemory.read(Mem_B_LightsOffPerc);
      int onTime=NumMins(InternalMemory.StdLightsOnHour_read(),InternalMemory.StdLightsOnMinute_read())-(actinicOffset+(2*lightOffset));
      int offTime=NumMins(InternalMemory.StdLightsOffHour_read(),InternalMemory.StdLightsOffMinute_read())+(actinicOffset+(2*lightOffset));
      int moonVal=ReefAngel.PWM.GetDaylightValueRaw();
      int channelVal=PWMSlopeHighRes(onTime/60,onTime%60,offTime/60,offTime%60,0,100,lightOffset,0);
      if (ReefAngel.PWM.GetChannelValueRaw(1)<=LightsOffPerc && channelVal>ReefAngel.PWM.GetDaylightValueRaw())
        ReefAngel.PWM.SetDaylightRaw(channelVal);
      if (ReefAngel.PWM.GetChannelValueRaw(3)<=LightsOffPerc && channelVal>ReefAngel.PWM.GetActinicValueRaw())
        ReefAngel.PWM.SetActinicRaw(channelVal);
      DaylightPWMValue=ReefAngel.PWM.GetDaylightValueRaw();
      ActinicPWMValue=ReefAngel.PWM.GetActinicValueRaw();
    void AcclimateLED() {
          if (acclDay > 0) {
            float acclActinicOffset=acclDay*(40.95*(((float)InternalMemory.read(Mem_B_AcclActinicOffset)/100)));
            float acclDaylightOffset=acclDay*(40.95*((float)InternalMemory.read(Mem_B_AcclDaylightOffset)/100));
            float endPerc;
            endPerc=40.95*InternalMemory.PWMSlopeEnd1_read();
            ReefAngel.PWM.SetChannelRaw(1,map(ReefAngel.PWM.GetChannelValueRaw(1),0,endPerc,0,endPerc-acclActinicOffset));
            endPerc=40.95*InternalMemory.PWMSlopeEnd3_read();
            ReefAngel.PWM.SetChannelRaw(3,map(ReefAngel.PWM.GetChannelValueRaw(3),0,endPerc,0,endPerc-acclActinicOffset));
            endPerc=40.95*InternalMemory.PWMSlopeEnd0_read();
            ReefAngel.PWM.SetChannelRaw(0,map(ReefAngel.PWM.GetChannelValueRaw(0),0,endPerc,0,endPerc-acclDaylightOffset));
            endPerc=40.95*InternalMemory.PWMSlopeEnd2_read();
            ReefAngel.PWM.SetChannelRaw(2,map(ReefAngel.PWM.GetChannelValueRaw(2),0,endPerc,0,endPerc-acclDaylightOffset));
#define LED_1to1      Box2_Port1
#define LED_2to1      Box2_Port2
#define LED_3to1      Box2_Port3
#define LED_BLUE      Box2_Port4
#define LED_WHITE     Box2_Port5
#define LED_MOON      Box2_Port6
#define LED_STORM     Box2_Port7
#define TRIGGER_STORM Box2_Port8
        void resetRelayBox(byte ID) {
  // toggle all relays except for the one selected
  for (int i=Box2_Port1;i<=Box2_Port4;i++) {
    if (i!=ID) ReefAngel.Relay.Auto(i);
void LEDPresets() {
  static byte lastPreset=0;
  DaylightPWMValue0=ReefAngel.PWM.GetChannelValueRaw(0);
  ActinicPWMValue1=ReefAngel.PWM.GetChannelValueRaw(1);
  DaylightPWMValue2=ReefAngel.PWM.GetChannelValueRaw(2);
  ActinicPWMValue3=ReefAngel.PWM.GetChannelValueRaw(3);
  if (ReefAngel.Relay.isMaskOn(LED_1to1)) {
    if (lastPreset!=1) resetRelayBox(LED_1to1);
    DaylightPWMValue0=90*40.95;
    ActinicPWMValue1=10*40.95;
    DaylightPWMValue2=90*40.95;
    ActinicPWMValue3=10*40.95;
    lastPreset=1;
  if (ReefAngel.Relay.isMaskOff(LED_1to1)) {
    if (lastPreset!=2) resetRelayBox(LED_1to1);
    DaylightPWMValue0=10*40.95;
    ActinicPWMValue1=90*40.95;
    DaylightPWMValue2=10*40.95;
    ActinicPWMValue3=90*40.95;
    lastPreset=2;
  if (ReefAngel.Relay.isMaskOn(LED_2to1)) {
    if (lastPreset!=3) resetRelayBox(LED_2to1);
    DaylightPWMValue0=60*40.95;
    ActinicPWMValue1=40*40.95;
    DaylightPWMValue2=60*40.95;
    ActinicPWMValue3=40*40.95;
    lastPreset=3;
  if (ReefAngel.Relay.isMaskOff(LED_2to1)) {
    if (lastPreset!=4) resetRelayBox(LED_2to1);
    DaylightPWMValue0=40*40.95;
    ActinicPWMValue1=60*40.95;
    DaylightPWMValue2=40*40.95;
    ActinicPWMValue3=60*40.95;
    lastPreset=4;
  if (ReefAngel.Relay.isMaskOn(LED_3to1)) {
    if (lastPreset!=5) resetRelayBox(LED_3to1);
    DaylightPWMValue0=75*40.95;
    ActinicPWMValue1=25*40.95;
    DaylightPWMValue2=75*40.95;
    ActinicPWMValue3=25*40.95;
    lastPreset=5;
  if (ReefAngel.Relay.isMaskOff(LED_3to1)) {
    if (lastPreset!=6) resetRelayBox(LED_3to1);
    DaylightPWMValue0=25*40.95;
    ActinicPWMValue1=75*40.95;
    DaylightPWMValue2=25*40.95;
    ActinicPWMValue3=75*40.95;
    lastPreset=6;
  if (ReefAngel.Relay.isMaskOn(LED_BLUE)) {
    if (lastPreset!=9) resetRelayBox(LED_BLUE);
    ActinicPWMValue1=80*40.95;
    ActinicPWMValue3=80*40.95;
    lastPreset=9;
  if (ReefAngel.Relay.isMaskOff(LED_BLUE)) {
    if (lastPreset!=10) resetRelayBox(LED_BLUE);
    ActinicPWMValue1=0;
    ActinicPWMValue3=0;
    lastPreset=10;
  if (ReefAngel.Relay.isMaskOn(LED_WHITE)) {
    if (lastPreset!=11) resetRelayBox(LED_WHITE);
    DaylightPWMValue0=80*40.95;
    ActinicPWMValue1=0;
    DaylightPWMValue2=80*40.95;
    ActinicPWMValue3=0;
    lastPreset=11;
  if (ReefAngel.Relay.isMaskOff(LED_WHITE)) {
    if (lastPreset!=12) resetRelayBox(LED_WHITE);
    lastPreset=12;
  if (ReefAngel.Relay.isMaskOn(LED_MOON)) {
    if (lastPreset!=13) resetRelayBox(LED_MOON);
    DaylightPWMValue=4095;
    ActinicPWMValue=4095;
    lastPreset=13;
  if (ReefAngel.Relay.isMaskOff(LED_MOON)) {
    if (lastPreset!=14) resetRelayBox(LED_MOON);
    DaylightPWMValue=0;
    ActinicPWMValue=0;
    lastPreset=14;
// Write updated values to the channels
void UpdateLED() {
  ReefAngel.PWM.SetChannelRaw(0,DaylightPWMValue0);
  ReefAngel.PWM.SetChannelRaw(1,ActinicPWMValue1);
  ReefAngel.PWM.SetChannelRaw(2,DaylightPWMValue2);
  ReefAngel.PWM.SetChannelRaw(3,ActinicPWMValue3);
  ReefAngel.PWM.SetDaylightRaw(DaylightPWMValue);
  ReefAngel.PWM.SetActinicRaw(ActinicPWMValue);
  byte LightsOffPerc=40.95*InternalMemory.read(Mem_B_LightsOffPerc);
  if (ReefAngel.PWM.GetChannelValueRaw(0)>=LightsOffPerc) ReefAngel.Relay.On(WhiteLeft); else ReefAngel.Relay.Off(WhiteLeft);
  if (ReefAngel.PWM.GetChannelValueRaw(1)>=LightsOffPerc) ReefAngel.Relay.On(BlueLeft); else ReefAngel.Relay.Off(BlueLeft);
void SetTide() {
  byte nightSpeed=InternalMemory.read(Mem_B_NightSpeed);
  byte tideMin=InternalMemory.read(Mem_B_TideMin);
  byte tideMax=InternalMemory.read(Mem_B_TideMax);
  // Set tide offsets
  tide.SetOffset(tideMin, tideMax);
  // Set tide speed. Slope in/out of Night Mode
  tide.SetSpeed(PWMSlope(sun.GetRiseHour()-1,sun.GetRiseMinute(),
    sun.GetSetHour(),sun.GetSetMinute(),nightSpeed+tideMin,DCPumpSpeed,120,nightSpeed+tideMin));
  // Show tide info on portal
  ReefAngel.CustomVar[Var_Tide]=tide.CalcTide();
void SetDCPump() {
  int ntmDelay=InternalMemory.read(Mem_B_NTMDelay)*60;
  int ntmTime=InternalMemory.read(Mem_B_NTMTime)*60;
  boolean nightDCPump=InternalMemory.read(Mem_B_NightDCPump);
  boolean feedingDCPump=InternalMemory.read(Mem_B_FeedingDCPump);
  static time_t t;
  ReefAngel.DCPump.FeedingSpeed=InternalMemory.read(Mem_B_FeedingSpeed);
  ReefAngel.DCPump.WaterChangeSpeed=InternalMemory.read(Mem_B_WCSpeed);
  DCPumpMode=InternalMemory.DCPumpMode_read();
  DCPumpSpeed=InternalMemory.DCPumpSpeed_read();
  DCPumpDuration=InternalMemory.DCPumpDuration_read();
  if ((now()-t > ntmDelay && now()-t < ntmTime+ntmDelay) && feedingDCPump) {
    // Post feeding mode
    DCPumpMode=Smart_NTM;
    DCPumpSpeed=InternalMemory.read(Mem_B_NTMSpeed);
    DCPumpDuration=InternalMemory.read(Mem_B_NTMDuration);
  } else if (!sun.IsDaytime() && nightDCPump) {
    DCPumpMode=Night;
    DCPumpSpeed=InternalMemory.read(Mem_B_NightSpeed);
    DCPumpDuration=InternalMemory.read(Mem_B_NightDuration);
  } else {
    if (DCPumpMode!=Night && ReefAngel.DCPump.Mode==Night)
      ReefAngel.DCPump.SetMode(Night_Stop,0,0);
  if (ReefAngel.DisplayedMenu==FEEDING_MODE) {
    t=now(); // Run post feeding mode when this counter stops
  } else if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE) {
    // Not needed anymore.
    // ReefAngel.DCPump.SetMode(Constant,25,0);
  } else {
    if ((DCPumpMode==Smart_NTM) || (DCPumpMode==ShortPulse)) DCPumpDuration=InternalMemory.read(Mem_B_NTMDuration);
    (DCPumpMode==Custom) ? DCPumpCustom() : ReefAngel.DCPump.SetMode(DCPumpMode,DCPumpSpeed,DCPumpDuration);
void RefugiumLight() {if (ReefAngel.DisplayedMenu==WATERCHANGE_MODE) {
        ReefAngel.Relay.On(Refugium);} }
void DCPumpCustom() {
  static boolean changeMode;
  byte rcSpeed, rcSpeedAS;
  // Define new modes
  const int BHazard=15;
  const int RA_ReefCrest=16;
  const int RA_Lagoon=17;
  const int RA_TidalSwell=18;
  const int RA_Smart_NTM=19;
  const int RA_ShortPulse=20;
  const int RA_LongPulse=21;
  byte tideSpeed=tide.CalcTide();
  byte tideMode=InternalMemory.read(Mem_B_TideMode);
  float pumpOffset=(float) InternalMemory.read(Mem_B_PumpOffset)/100;
  byte RandomModes[]={ ReefCrest, TidalSwell, Smart_NTM, Lagoon, ShortPulse, LongPulse, BHazard, Else, Sine, Constant };
//  if (now()%SECS_PER_DAY!=0 && InternalMemory.read(Mem_B_RandomMode)) changeMode=true;
//  if (now()%SECS_PER_DAY==0 && changeMode) {
  if (now()%(6*SECS_PER_HOUR)!=10 && InternalMemory.read(Mem_B_RandomMode)) changeMode=true;
  if (now()%(6*SECS_PER_HOUR)==10 && changeMode) {
    tideMode=random(100)%sizeof(RandomModes);
    InternalMemory.write(Mem_B_TideMode,tideMode);
    changeMode=false;
  // Choose another random mode if triggered
  if (InternalMemory.read(Mem_B_ForceRandomTide)) {
    InternalMemory.write(Mem_B_ForceRandomTide,false);
  ReefAngel.CustomVar[Var_TideMode]=tideMode+1;
  switch (RandomModes[tideMode]) {
    case ReefCrest: {
      ReefAngel.DCPump.SetMode(ReefCrest,tideSpeed,DCPumpDuration);
      return;
      break;
    case Lagoon: {
      ReefAngel.DCPump.SetMode(Lagoon,tideSpeed,DCPumpDuration);
      return;
      break;
    case TidalSwell: {
      ReefAngel.DCPump.SetMode(TidalSwell,tideSpeed,DCPumpDuration);
      return;
      break;
    case Smart_NTM: {
      ReefAngel.DCPump.SetMode(Smart_NTM,tideSpeed,DCPumpDuration);
      return;
      break;
    case ShortPulse: {
      ReefAngel.DCPump.SetMode(ShortPulse,tideSpeed,DCPumpDuration);
      return;
      break;
    case LongPulse: {
      ReefAngel.DCPump.SetMode(LongPulse,tideSpeed,DCPumpDuration);
      return;
      break;
    case RA_ReefCrest: {
      rcSpeed=ReefCrestMode(tideSpeed,DCPumpDuration*2,true);
      rcSpeedAS=ReefCrestMode(tideSpeed,DCPumpDuration*2,false);
      break;
    case RA_Lagoon: {
      rcSpeed=ReefCrestMode(tideSpeed,DCPumpDuration,true);
      rcSpeedAS=ReefCrestMode(tideSpeed,DCPumpDuration,false);
      break;
    case RA_TidalSwell: {
      rcSpeed=TidalSwellMode(tideSpeed,true);
      rcSpeedAS=TidalSwellMode(tideSpeed,false);
      break;
    case RA_Smart_NTM: {
      rcSpeed=NutrientTransportMode(0,tideSpeed,DCPumpDuration*50,true);
      rcSpeedAS=NutrientTransportMode(0,tideSpeed,DCPumpDuration*50,false);
      break;
    case RA_ShortPulse: {
      rcSpeed=ShortPulseMode(0,tideSpeed,DCPumpDuration*50,true);
      rcSpeedAS=ShortPulseMode(0,tideSpeed,DCPumpDuration*50,false);
      break;
    case RA_LongPulse: {
      rcSpeed=LongPulseMode(0,tideSpeed,DCPumpDuration,true);
      rcSpeedAS=LongPulseMode(0,tideSpeed,DCPumpDuration,false);
      break;
    case Else: {
      rcSpeed=ElseMode(tideSpeed,DCPumpDuration*2,true);
      rcSpeedAS=ElseMode(tideSpeed,DCPumpDuration*2,false);
      break;
    case BHazard: {
      rcSpeed=millis()%1200>800?tideSpeed:0;
      rcSpeedAS=millis()%1200<400?0:tideSpeed;
      break;
    case Sine: {
      rcSpeed=SineMode(tideSpeed-tideMin,tideSpeed+tideMin,DCPumpDuration*100,true);
      rcSpeedAS=SineMode(tideSpeed-tideMin,tideSpeed+tideMin,DCPumpDuration*100,false);
      break;
    default: {
      rcSpeed=tideSpeed;
      rcSpeedAS=tideSpeed;
      pumpOffset=(float) InternalMemory.read(Mem_B_GyreOffset)/100;
  ReefAngel.DCPump.SetMode(Custom,rcSpeedAS*pumpOffset,tide.isOutgoing());
  ReefAngel.DCPump.SetMode(Custom,rcSpeed,tide.isIncoming());
void NextDCPumpMode() {
      DCPumpMode++;
      if (DCPumpMode > 12) {
        DCPumpMode=0;
        DCPumpSpeed=50; // Constant
      } else if (DCPumpMode == 1) {
        DCPumpSpeed=40; // Lagoon
      } else if (DCPumpMode == 2) {
        DCPumpSpeed=45; // Reef Crest
      } else if (DCPumpMode == 3) {
        DCPumpSpeed=55; DCPumpDuration=10; // Short Pulse
      } else if (DCPumpMode == 4) {
        DCPumpSpeed=55; DCPumpDuration=20; // Long Pulse
      } else if (DCPumpMode == 5) {
        DCPumpDuration=InternalMemory.read(Mem_B_NTMDuration); // Smart_NTM
      } else if (DCPumpMode == 6) {
        DCPumpSpeed=50; DCPumpDuration=10; // Smart_TSM
      } else if (DCPumpMode == 7) {
        DCPumpMode=9; // Night
      } else if (DCPumpMode == 10) {
        DCPumpSpeed=65; DCPumpDuration=5; // Storm
      } else if (DCPumpMode == 11) {
        DCPumpSpeed=45; DCPumpDuration=10; // Custom
      if (DCPumpMode!=InternalMemory.DCPumpMode_read())
        InternalMemory.DCPumpMode_write(DCPumpMode);
      if (DCPumpSpeed!=InternalMemory.DCPumpSpeed_read())
        InternalMemory.DCPumpSpeed_write(DCPumpSpeed);
      if (DCPumpDuration!=InternalMemory.DCPumpDuration_read())
        InternalMemory.DCPumpDuration_write(DCPumpDuration);
        // Menu Code
void MenuEntry1() {
  ReefAngel.FeedingModeStart();
void MenuEntry2() {
void MenuEntry3() {
  ReefAngel.ATOClear();
    void MenuEntry4() {
      NextDCPumpMode();
void MenuEntry5() {
  ReefAngel.SetupCalibratePH();
void MenuEntry6() {
  ReefAngel.OverheatClear();
void MenuEntry7() {
  ReefAngel.SetupDateTime();
void MenuEntry8() {
      // Toggle refugium light between on/auto.
      ReefAngel.Relay.Override(Refugium, ReefAngel.Relay.Status(Refugium)+1);
// Custom Main Screen
void DrawCustomMain() {
  const int NumScreens=4;
  static boolean drawGraph=true;
  // Main Header
  // ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 35, 2,"Troy's Reef");
  ReefAngel.LCD.DrawDate(5,2);
  ReefAngel.LCD.Clear(COLOR_BLACK, 1, 11, 128, 11);
  // Param Header
  DrawParams(5,14);
  switch (ScreenID) {
    case 0:
      if (drawGraph) { ReefAngel.LCD.DrawGraph(5,40); drawGraph=false; }
      break;
    case 1: { DrawStatus(5,40); break; }
    case 2: { DrawSunMoon(5,40); break; }
    case 3: { DrawClouds(5,50); break; }
  // Draw Relays
  DrawRelays(12,94);
  // Date+Time
  // ReefAngel.LCD.DrawDate(5,122);
  if (ReefAngel.Joystick.IsLeft()) {
    ScreenID--; drawGraph=true;
  if (ReefAngel.Joystick.IsRight()) {
    ScreenID++; drawGraph=true;
  if (ScreenID<0) ScreenID=NumScreens-1;
  if (ScreenID>=NumScreens) ScreenID=0;
void DrawCustomGraph() {
  if (ScreenID==0)
    ReefAngel.LCD.DrawGraph(5, 40);
void DrawParams(int x, int y) {
  char buf[16];
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x+5,y,"Temp:");
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x+80, y, "PH:");
  // Temp and PH
  y+=2;
  ConvertNumToString(buf, ReefAngel.Params.Temp[T2_PROBE], 10);
  ReefAngel.LCD.DrawText(T2TempColor, DefaultBGColor, x+45, y, buf);
  y+=6;
  ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, x+80, y, buf, Num8x16);
  y+=5;
  ConvertNumToString(buf, ReefAngel.Params.Temp[T3_PROBE], 10);
  ReefAngel.LCD.DrawText(T3TempColor, DefaultBGColor, x+45, y, buf);
void DrawStatus(int x, int y) {
  int t=x;
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,15,y,"High",Font8x16);
  ReefAngel.LCD.DrawLargeText(COLOR_INDIGO,DefaultBGColor,85,y,"Low",Font8x16);
    ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_GREEN);
  } else {
    ReefAngel.LCD.FillCircle(55,y+3,5,COLOR_RED);
  if (ReefAngel.LowATO.IsActive()) {
    ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_GREEN);
  } else {
    ReefAngel.LCD.FillCircle(70,y+3,5,COLOR_RED);
  y+=12;
 // DC Pump Mode
      ReefAngel.LCD.DrawText(0,255,x,y,"DC:"); x+=20;
      ReefAngel.LCD.Clear(DefaultBGColor,x,y,t+(128-t),y+8);
      if (DCPumpMode == 0) ReefAngel.LCD.DrawLargeText(COLOR_GREEN,255,x,y,"Constant");
      else if (DCPumpMode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,x,y,"Lagoon");
      else if (DCPumpMode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,x,y,"Reef Crest");
      else if (DCPumpMode == 3) ReefAngel.LCD.DrawLargeText(COLOR_RED,255,x,y,"Short Pulse");
      else if (DCPumpMode == 4) ReefAngel.LCD.DrawLargeText(COLOR_RED,255,x,y,"Long Pulse");
      else if (DCPumpMode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,x,y,"Smart NTM");
      else if (DCPumpMode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,x,y,"Tidal Swell");
      else if (DCPumpMode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,x,y,"Night");
      else if (DCPumpMode == 10) ReefAngel.LCD.DrawLargeText(COLOR_BLUE,0,x,y,"Storm");
      else if (DCPumpMode == 11) ReefAngel.LCD.DrawLargeText(COLOR_BLUE,255,x,y,"Custom");
      y+=10; x=t;
      ReefAngel.LCD.DrawText(0,255,x,y,"DC Speed:"); x+=60;
      ReefAngel.LCD.Clear(DefaultBGColor,x,y,128,y+8);
      ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,x,y,DCPumpSpeed); x+=15;
      ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,x,y,"/"); x+=10;
      ReefAngel.LCD.DrawText(COLOR_BLUE, DefaultBGColor,x,y,DCPumpDuration);
      y+=10; x=t;
  // Display Acclimation timer
  if (acclDay > 0) {
    ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,x,y,"Acclimation Day:"); x+=100;
    ReefAngel.LCD.DrawSingleMonitor(acclDay,DefaultFGColor,x,y,1);
  } else {
void DrawSunMoon(int x, int y) {
  char buf[16];
  int t=x;
  y+=2;
  /// Display Sunrise / Sunset
  sprintf(buf, "%02d:%02d", sun.GetRiseHour(), sun.GetRiseMinute());
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"Rise:"); x+=31;
  ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,buf);
  sprintf(buf, "%02d:%02d", sun.GetSetHour(), sun.GetSetMinute()); x+=36;
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"Set:"); x+=25;
  y+=15; x=t;
  /// Display Moonrise / Moonset
  sprintf(buf, "%02d:%02d", Moon.riseH, Moon.riseM);
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"MR:"); x+=21;
  sprintf(buf, "%02d:%02d", Moon.setH, Moon.setM); x+=36;
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"MS:"); x+=21;
  ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,buf); x+=36;
  if (Moon.isUp) ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,"@");
    else ReefAngel.LCD.DrawText(COLOR_RED,DefaultBGColor,x,y,"_");
  y+=10; x=t;
  // MoonPhase
  ReefAngel.LCD.DrawText(0,255,x,y,"Moon:");
  ReefAngel.LCD.Clear(DefaultBGColor,x+32,y,128,y+8);
  ReefAngel.LCD.DrawText(COLOR_MAGENTA,255,x+32,y,MoonPhaseLabel());
  y+=10; x=t;
  // MoonLight %
  ReefAngel.LCD.DrawText(COLOR_BLACK,DefaultBGColor,x,y,"MoonLights:"); x+=68;
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetDaylightValue(),DPColor,x,y,1);
  x+=5*(intlength(ReefAngel.PWM.GetDaylightValue())+1);
  ReefAngel.LCD.DrawText(DPColor, DefaultBGColor, x, y, "%");
void DrawRelays(int x, int y) {
  // Draw Relays
  ReefAngel.LCD.DrawOutletBox(x, y, TempRelay);
  y+=12;
  y+=12;
  TempRelay = ReefAngel.Relay.RelayDataE[1];
  TempRelay &= ReefAngel.Relay.RelayMaskOffE[1];
  TempRelay |= ReefAngel.Relay.RelayMaskOnE[1];
void DelayedOnFeedMode(byte relay) {
  static unsigned long startTime=now();
  if ( (startTime==LastStart || ReefAngel.DisplayedMenu==WATERCHANGE_MODE) && ReefAngel.HighATO.IsActive()) {
    ReefAngel.Relay.On(relay);
  } else {
    ReefAngel.Relay.DelayedOn(relay);
#define Clouds_Every_X_Days InternalMemory.read(Mem_B_CloudsEveryXDays)
#define Cloud_Chance_per_Day InternalMemory.read(Mem_B_CloudChancePerDay)
// Minimum number of minutes for cloud duration.  Don't use min duration of less than 6
#define Min_Cloud_Duration InternalMemory.read(Mem_B_MinCloudDuration)
#define Max_Cloud_Duration InternalMemory.read(Mem_B_MaxCloudDuration)
#define Min_Clouds_per_Day InternalMemory.read(Mem_B_MinCloudsPerDay)
#define Max_Clouds_per_Day InternalMemory.read(Mem_B_MaxCloudsPerDay)
// In this example, start cloud after noon
#define Start_Cloud_After NumMins(InternalMemory.read(Mem_B_StartCloudAfterHour),InternalMemory.read(Mem_B_StartCloudAfterMin))
#define End_Cloud_Before NumMins(InternalMemory.read(Mem_B_EndCloudBeforeHour),InternalMemory.read(Mem_B_EndCloudBeforeMin))
#define Lightning_Chance_per_Cloud InternalMemory.read(Mem_B_LightningChance)
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes
// of effects or unforseen result could happen.
// In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the
// 250 minutes (or 500 minutes) can fit in that 510 minutes window.
// Add Random Lightning modes
#define Calm 0    // No lightning
#define Slow 1    // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2    // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3    // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4   // Like Mega, but with more lightning
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static byte lightningMode=0;
void CheckCloud()
  // Example:  { Calm, Fast, Mega, Mega2 } to randomize all four modes.
  // { Mega2 } for just Mega2.  { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
  byte LightningModes[] = {Slow};
  static time_t DelayCounter=millis();    // Variable for lightning timing.
  static int DelayTime=random(1000);      // Variable for lightning timimg.
#ifdef forcecloudcalculation
  if (cloudchance==255)
#else
#endif
      // Commenting out to see if it's interfering with our other seed.
      // randomSeed(millis());    // Seed the random number generator
      cloudchance=random(100);
      // If we have cloud today
      if (cloudchance)
        lightningchance=random(100);
        // if picked number is greater than Lightning_Chance_per_Cloud, we will not have lightning today
        if (lightningchance>Lightning_Chance_per_Cloud) lightningchance=0;
  if (ReefAngel.Relay.isMaskOn(LED_STORM)) {
    InternalMemory.write(Mem_B_EnableStorm,false);
  if (ReefAngel.Relay.isMaskOff(LED_STORM)) {
    InternalMemory.write(Mem_B_EnableStorm,true);
  if (InternalMemory.read(Mem_B_EnableStorm)) return;
  if (cloudchance)
    if (ReefAngel.Relay.isMaskOff(TRIGGER_STORM))      // Change this to whatever port you want to use as a trigger.
      cloudstart = NumMins(hour(), minute());
      ReefAngel.Relay.Auto(TRIGGER_STORM);    // Here, too.
    //is it time for cloud yet?
      // Increase Blue channel first for better effect and to compensate for drop in Whites
      ActinicPWMValue1=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,ActinicPWMValue1,ActinicPWMValue1+DaylightPWMValue0,180);
      ActinicPWMValue3=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,ActinicPWMValue3,ActinicPWMValue3+DaylightPWMValue2,180);
      DaylightPWMValue0=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,DaylightPWMValue0,0,180);
      DaylightPWMValue2=ReversePWMSlopeHighRes(cloudstart,cloudstart+cloudduration,DaylightPWMValue2,0,180);
      if (chooseLightning)
        chooseLightning=false;
      switch (lightningMode)
      case Calm:
        break;
      case Mega:
        // Lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
          // Send the trigger
          Strike();
          DelayCounter=millis();    // If we just had a round of flashes, then lets put in a longer delay
          DelayTime=random(1000);   // of up to a second for dramatic effect before we do another round.
        break;
      case Mega2:
        // Higher lightning chance from beginning of cloud through the end.  Chance increases with darkness of cloud.
          Strike();
        break;
      case Fast:
          Strike();
        break;
      case Slow:
        // Slow lightning for 5 seconds in the middle of the cloud.  Suitable for slower ELN style drivers
        if (lightningchance && second()%40<8)
          SlowStrike();
        break;
      default:
        break;
      cloudindex++;
      if (cloudindex < numclouds)
  // Cloud ON option - Clouds every minute
  if (ReefAngel.Relay.isMaskOn(TRIGGER_STORM) && now()%60<10)
    SlowStrike();
void SlowStrike()
    int r = random(100);
    if (r<20) lightningstatus=1;
    else lightningstatus=0;
    if (lightningstatus)
      // Let's separate left and right both.
      if (r<14) {
        DaylightPWMValue0=4095;
        DaylightPWMValue2=4095;
        ActinicPWMValue1=4095;
        ActinicPWMValue3=4095;
      } else if (r<17) {
        DaylightPWMValue0=100;
      } else {
        DaylightPWMValue2=100;
    delay(1);
void DrawClouds(int x, int y)
    ReefAngel.LCD.DrawText(0,255,x,y,"C"); x+=6;
    ReefAngel.LCD.DrawText(0,255,x,y,"00:00"); x+=34;
    ReefAngel.LCD.DrawText(0,255,x,y,"L"); x+=6;
    ReefAngel.LCD.DrawText(0,255,x,y,"00:00"); x=5;
      int x=0;
      else x=17;
      ReefAngel.LCD.DrawText(0,255,x,y,(cloudstart/60));
      ReefAngel.CustomVar[0]=cloudstart/60; // Write the hour of the next cloud to custom variable for Portal reporting
      else x=35;
      ReefAngel.LCD.DrawText(0,255,x,y,(cloudstart%60));
      ReefAngel.CustomVar[1]=cloudstart%60; // Write the minute of the next cloud to custom variable for Portal reporting
    ReefAngel.LCD.DrawText(0,255,x+85,y,cloudduration);
    ReefAngel.CustomVar[2]=(cloudduration);    // Put the duration of the next cloud in a custom var for the portal
    if (lightningchance)
      int x=0;
      if (((cloudstart+(cloudduration/3))/60)>=10) x=51;
      else x=57;
      ReefAngel.LCD.DrawText(0,255,x,y,((cloudstart+(cloudduration/3))/60));
      ReefAngel.CustomVar[6]=(cloudstart+(cloudduration/2))/60;    // Write the hour of the next lightning to a custom variable for the Portal
      if (((cloudstart+(cloudduration/3))%60)>=10) x=69;
      else x=75;
        ReefAngel.LCD.DrawText(0,255,x,y,((cloudstart+(cloudduration/3))%60)); // Write the minute of the next lightning to a custom variable for the Portal
        ReefAngel.CustomVar[7]=(cloudstart+(cloudduration/2))%60;
void Strike()
  int a=random(1,5);    // Pick a number of consecutive flashes from 1 to 4.
  for (int i=0; i<a; i++)
    // Flash on
    int newdata=4095;
    Wire.beginTransmission(0x40);      // Address of the dimming expansion module
    Wire.write(0x8+(4*0));             // 0x8 is channel 0, 0x12 is channel 1, etc.  This is channel 0.
    Wire.write(newdata&0xff);          // Send the data 8 bits at a time.  This sends the LSB
    Wire.write(newdata>>8);            // This sends the MSB
    Wire.endTransmission();
    Wire.write(0x8+(4*2));             // 0x8 is channel 0, 0x12 is channel 1, etc.  This is channel 2.
    int randy=random(20,80);    // Random number for a delay
    if (randy>71) randy=((randy-70)/2)*100;    // Small chance of a longer delay
    delay(randy);                // Wait from 20 to 69 ms, or 100-400 ms
    // Flash off.  Return to baseline.
    newdata=ReefAngel.PWM.GetChannelValueRaw(0);   // Use the channel number you're flashing here
    Wire.beginTransmission(0x40);    // Same as above
    newdata=ReefAngel.PWM.GetChannelValueRaw(2);   // Use the channel number you're flashing here
    delay(random(30,50));                // Wait from 30 to 49 ms
    wdt_reset();    // Reset watchdog timer to avoid re-boots
  cstart*=60;
  cend*=60;
  if (n>cend) return (int) PWMStart;
int ReversePWMSlopeHighRes(long cstart,long cend,int PWMStart,int PWMEnd, byte clength)
  cstart*=60;
  cend*=60;
Re: New IDE v1.6.8
Posted: Wed Nov 23, 2016 9:53 am
by cosmith71
You need to switch your board type back to RA+ in the tools menu.
Re: New IDE v1.6.8
Posted: Wed Nov 23, 2016 10:10 am
by troylong45
now i get this is it just telling me to lower case "progmem"?
Arduino:  (Reef Angel compilation) v1.6.8 (Windows 8.1), Board: "Reef Angel Plus Controller"
Watchdog Timer
Version Menu
Dimming Signal
Wifi Attachment
Custom Main Screen
Custom Variable
Custom Menu
Moon Phase Label
troyraino09112016:42: error: variable 'menu_items' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
exit status 1
Re: New IDE v1.6.8
Posted: Wed Nov 23, 2016 10:58 am
It's your custom menu.
Look at the original post regarding this issue.
Re: New IDE v1.6.8
Posted: Wed Nov 23, 2016 1:13 pm
by troylong45
ok i got it for verify now old code had PROGMEM before const char *menu_items[] = { removed and and now verified code
now i get this error trying to upload the code
Watchdog Timer
Version Menu
Dimming Signal
Wifi Attachment
Custom Main Screen
Custom Variable
Custom Menu
Moon Phase Label
Sketch uses 87,842 bytes (34%) of program storage space. Maximum is 253,952 bytes.
Global variables use 3,069 bytes (37%) of dynamic memory, leaving 5,123 bytes for local variables. Maximum is 8,192 bytes.
C:\Program Files (x86)\Reef Angel Controller\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware\tools\avr/etc/avrdude.conf -v -patmega2560 -cwiring -PCOM50 -b115200 -D -Uflash:w:C:\Users\ANNLON~1\AppData\Local\Temp\build9c358ac95c18b46f3958cd993d59bff1.tmp/sketch_edit_troyraino09112016_fix_menu_verify.ino.hex:i
Rebooting Reef Angel Controller.
avrdude: Version 6.3a, compiled on Jul  5 2016 at 00:43:48
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Reef Angel Controller\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM50
         Using Programmer              : wiring
         Overriding Baud Rate          : 115200
avrdude: ser_open(): can't open device "\\.\COM50": The system cannot find the file specified.
avrdude: ser_drain(): read error: The handle is invalid.
avrdude: ser_send(): write error: sorry no info avail
avrdude: stk500_send(): failed to send command to serial port
avrdude: ser_recv(): read error: The handle is invalid.
avrdude: stk500v2_getsync(): timeout communicating with Reef Angel Controller
avrdude done.  Thank you.
Reef Angel Controller updated.
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Re: New IDE v1.6.8
Posted: Wed Nov 23, 2016 1:26 pm
by troylong45
i think i got it the port was not selected
