Is my relay box PWM or analog
Posted: Thu Jun 09, 2016 4:43 pm
by madweazl
Purchased an RA+ used and havent been able to figure out which relay box I've got (have two but they appear to be the same). From searches, analog had a sticker on the bottom; mine have no sticker but it's possible they did at one time. Is there any other way to know without breaking open the relay box? I unscrewed the main power and could see a pair of jumpers at the far end near the USB connector. The jumper looked to be on the pins nearest the USB connector; does this provide anything useful?
If I do end up opening the box, what is the best method of doing so without destroying it?
Re: Is my relay box PWM or analog
Posted: Fri Jun 10, 2016 6:16 am
by cosmith71
That sounds like PWM. If you do open the box, be aware that the label on the jumpers is reversed (PWM/Analog). IIRC, all you have to do is remove the screws on the top and then pry to get it to come apart.
Posted: Fri Jun 10, 2016 1:05 pm
by madweazl
cosmith71 wrote:That sounds like PWM. If you do open the box, be aware that the label on the jumpers is reversed (PWM/Analog). IIRC, all you have to do is remove the screws on the top and then pry to get it to come apart.
If it's a PWM box there is no way to change it to analog (unless the analog components were installed originally), correct?
Posted: Fri Jun 10, 2016 1:14 pm
Yes
Posted: Fri Jun 10, 2016 1:17 pm
by madweazl
This is what's inside
Posted: Fri Jun 10, 2016 1:20 pm
Just move those 2 jumpers to the other side.
The label is inverted.
It shows Analog/PWM, but it is in fact PWM/Analog
Posted: Fri Jun 10, 2016 1:26 pm
by madweazl
rimai wrote:Just move those 2 jumpers to the other side.
Excellent news; thank you rimai!
Posted: Fri Jun 10, 2016 1:35 pm
by madweazl
madweazl wrote:rimai wrote:Just move those 2 jumpers to the other side.
So do the PWM only boxes not have the jumpers?
Posted: Fri Jun 10, 2016 1:36 pm
They do.
They are set just like in the photo.
That's why your box is currently PWM and not analog.
Posted: Fri Jun 10, 2016 1:42 pm
by madweazl
rimai wrote:They do.
So there is no difference in the relay boxes? I thought there were versions of the box that didnt have the capability to do analog.
Posted: Fri Jun 10, 2016 1:58 pm
That's I mentioned above.
Just move the jumpers to turn your box into an analog version.
Older version didn't have the capability. Luckily, yours can
Posted: Fri Jun 10, 2016 2:03 pm
by madweazl
rimai wrote:That's I mentioned above.
Awesome, thanks again for the information rimai
