Controller heater temp issue
Posted: Sun Jun 12, 2016 10:39 am
by madweazl
Controller is set to turn heater on at 77° and off at 78° but it actually turns on at 79.1° and off at 79.9° according to temp sensor 1 (no other temp sensors plugged in). I dont mind the delta between the two but it seemed odd that the controller and sensor were off by a degree. Is this normal behavior? Is it something I can correct?
Re: Controller heater temp issue
Posted: Sun Jun 12, 2016 11:05 am
Can you post your code?
Posted: Sun Jun 12, 2016 11:32 am
by madweazl
Looking at the code, it shows 79° and 80° but that isnt what is displayed on the actual controller when you go into the temp menu. Can that not be adjusted on the fly?
ReefAngel.FeedingModePorts = Port7Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port2,790,800 );
ReefAngel.StandardLights( Port4,22,0,10,0 );
ReefAngel.StandardLights( Port5,10,0,22,0 );
ReefAngel.StandardLights( Port6,10,0,22,0 );
ReefAngel.PWM.SetDaylight( PWMParabola(10,0,22,0,10,30,10) );
ReefAngel.PWM.SetActinic( PWMParabola(10,0,22,0,10,40,10) );
Posted: Sun Jun 12, 2016 1:49 pm
You're set to go on between 79 and 80... not 77 and 78...
try:
ReefAngel.StandardHeater( Port2,770,780 );
Posted: Sun Jun 12, 2016 4:32 pm
If you want to set it on the fly, you need to generate a code with internal memory and not hard coded.
Posted: Sun Jun 12, 2016 8:05 pm
In which case
ReefAngel.StandardHeater(Port2);
Posted: Mon Jun 13, 2016 8:38 am
by madweazl
Thanks; I didn't realize it had to be internal memory when you made adjustments from the controller, I thought that was only through the portal/app.
