Dosing Pump
Posted: Mon Jun 20, 2016 4:42 pm
by LucianoB
Hi Friends, What I need for use one Dosing Pump? Off course- I know, buy one Dosing Pump in the Store but something else? Where I will need connect that?
Thank you a lot.
Re: Dosing Pump
Posted: Tue Jun 21, 2016 3:01 am
by cosmith71
You plug it into an outlet on the relay box. You will need airline tubing as well.
Re: Dosing Pump
Posted: Tue Jun 21, 2016 4:27 am
by LucianoB
cosmith71 wrote:You plug it into an outlet on the relay box. You will need airline tubing as well.
Thank you for your answer. So in the relay box I will need use one 110v/12v Converter right? If I dont like use one Converter, what I need, do you know?
Regards
Re: Dosing Pump
Posted: Tue Jun 21, 2016 6:04 pm
by cosmith71
Yes. It comes with the pump.
