portal not working, phone app is
Related to the Portal
psyrob
Post by psyrob »
My portal page keeps showing data from February, when I reload it it shows todays date for a second then goes back to february. Just before it goes back to February, the Connection Status says "Error - 0" for a brief section.
My iphone app is current and both are pointing to the same IP address and port and I confirmed that my port is open. Any ideas why the portal isn't updating even as my iphone app is?
thanks
Re: portal not working, phone app is
Can you post what you get when you browse http://ipaddress:2000/r99 ?
psyrob
Post by psyrob »
Here is what came up. Now, when I check the portal from work, it is current. Could it be only happening from my house, like my router changing the IP?
<RA>
<ID>psyrob</ID>
<T1>811</T1>
<T2>784</T2>
<T3>807</T3>
<PH>800</PH>
<R>175</R>
<RON>0</RON>
<ROFF>246</ROFF>
<ATOLOW>0</ATOLOW>
<ATOHIGH>0</ATOHIGH>
<EM>0</EM>
<EM1>2</EM1>
<REM>0</REM>
<BID>1</BID>
<AF>1</AF>
<SF>0</SF>
<PWMA>91</PWMA>
<PWMD>50</PWMD>
<PWMAO>255</PWMAO>
<PWMDO>255</PWMDO>
<DCM>13</DCM>
<DCS>100</DCS>
<DCD>22</DCD>
<DCT>30</DCT>
</RA>
psyrob
Post by psyrob »
spoke too soon: now it is back to february data
Ok, there can be two things.
You are using timer 4 or your wifi attachment is not properly configured.
Let's start with the easier. Can you post your code?
psyrob
Post by psyrob »
Sorry for the delay, been busy at work: here is my code, note from my banner that the portal is showing data from February... Does this give any answers?
    ReefAngel.LightsOnPorts = Port2Bit | Port3Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port7Bit;
    ReefAngel.ActinicLights( Port2 );
    ReefAngel.DayLights( Port3 );
    ReefAngel.ActinicLights( Port4 );
    ReefAngel.SingleATOLow( Port5 );
    ReefAngel.StandardFan( Port8 );
    ReefAngel.Portal( "psyrob" );
    ReefAngel.DDNS( "99.90.0.55:2000" ); // Your DDNS is psyrob-99.90.0.55:2000.myreefangel.com
}/code]
Check under Portal Settings in the Portal and make sure you don't have a key setup.
Also your DDNS name. Should just be a name and shouldn't have your IP and Port.
psyrob
Post by psyrob »
do you mean the ddns name should be in my code, and not the IP and Port? As in this line in the code:
should really be
ReefAngel.DDNS("psyrob");//
more like controller1. Then your DDNS name will be psyrob-controller1.myreefangel.com
But the key is more than likely your current problem.
psyrob
Post by psyrob »
Well, I'm still not able to connect. I redid my code thru the wizard, and this is what it created:
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port7Bit;
    ReefAngel.StandardFan( Port1 );
    ReefAngel.DayLights( Port4 );
And again, my iphone app works but the portal does not. And I don't have a key set up on the portal. I checked that. I will try and change in the code "psyrob" to "psy-rob-controller1.myreefangel.com" and see if that works.
any other ideas?
psyrob
Post by psyrob »
So I switched my code at the end as follows:
    ReefAngel.DDNS( "psyrob-controller1.myreefangel.com" ); // Your DDNS is psyrob-99.90.0.55:2000.myreefangel.com
and it didn't work at first , it went to February data, but after refreshing the page a few times, current data popped up. I will keep an eye on it, but thanks for the help
