Wifi flashing blue
Posted: Sun Jul 17, 2016 6:15 pm
by jjdezek
My wifi has been working fine. Left the house and had a thunderstorm roll through, came home to wifi flashing blue. I unplugged it and plugged it back in but still flashing blue. Do I need to reprogram it? What would cause it to start flashing blue? Everything else is connected to wifi in my house except my reefangel.
Re: Wifi flashing blue
Posted: Mon Jul 18, 2016 2:53 pm
by jjdezek
Well now it's back to flashing green but I still can't access it from the app but the portal works.
Posted: Mon Jul 18, 2016 3:27 pm
ip changed?
Posted: Mon Jul 18, 2016 4:22 pm
by jjdezek
The IP address I used is the one showing on the portal. Is that not the correct IP
Posted: Mon Jul 18, 2016 4:53 pm
Your internal ip may have changed and you would need to reconfigure your port forwarding.
Posted: Mon Jul 18, 2016 5:29 pm
by jjdezek
Figured it out. I had to delete the file in the app and start a new controller file and it started working. IP address stayed the same so not sure what happened or what caused it.
