When I put the system into feeding mode or water change mode my expansion relay reboots.
I recent installed the RA + board, but have never had 2 expansions on this unit.
Any thoughts?
here is my code
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port5Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.WaterChangePortsE[0] = Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port4Bit | Port6Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port1Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
ReefAngel.CustomLabels[0]="Return";
ReefAngel.CustomLabels[2]="";
ReefAngel.CustomLabels[3]="SumpHeater";
ReefAngel.CustomLabels[4]="LeftVortech";
ReefAngel.CustomLabels[5]="TankHeater";
ReefAngel.CustomLabels[6]="RightVortech";
ReefAngel.CustomLabels[7]="";
ReefAngel.CustomLabels[8]="Radion";
ReefAngel.CustomLabels[9]="StndLight";
ReefAngel.CustomLabels[10]="";
ReefAngel.CustomLabels[11]="FugeLight";
ReefAngel.CustomLabels[12]="";
ReefAngel.CustomLabels[13]="";
ReefAngel.CustomLabels[14]="Dosing1";
ReefAngel.CustomLabels[15]="Dosing2";
ReefAngel.MoonLights( Box1_Port4 );
ReefAngel.StandardHeater( Port4 );
ReefAngel.DosingPumpRepeat1( Box1_Port7 );
ReefAngel.DosingPumpRepeat2( Box1_Port8 );
ReefAngel.Portal( "XXXXXX" );
Expansion Reboots
projectx
Re: Expansion Reboots
On another note, when the system comes out of water change or feeding the expansion doesnt power cycle
projectx
So something else that just showed up. If port 1 the return pump port is in the on state and not in auto. the expansion does not reboot.
Any ideas?
Any ideas?
Can you try removing the custom labels to see if that is affecting anything?
projectx
Ill give it a shot and see. I know I had an issue with a reboot loop with some of the labels
projectx2
I set all of the labels to blank just "" same thing happens
Sent from my SM-G935V using Tapatalk
Remove the reference from the code.
Even if it is commented, it is still enabled.
When you are in water change mode, go to a browser within the same network and go to http://ipaddress:2000/r99
Send me the XML data you get back.
