problem with relay box?
Posted: Mon Aug 08, 2016 9:46 pm
by Meshmez
I was taking the relay box off my old tank to move to my new tank, and i heard a rattling inside. I was able to get a small piece of something to fall out. I have attached pictures. its a little under 1/4" square. It looks like the casing on an electrical component, a capacitor or something. Is this anything to be worried about?
Re: problem with relay box?
Posted: Sat Aug 13, 2016 9:07 pm
by Meshmez
anyone ?
Posted: Sat Aug 13, 2016 9:15 pm
You should be fine, but if you want it replaced, send it back.
Those are part of the dampening circuit if you use Koralias as wavemakers.
Posted: Sun Aug 14, 2016 10:16 am
by Meshmez
Thanks for the response Roberto! If i just use it as is, is there any problem/danger?
Posted: Sun Aug 14, 2016 1:50 pm
It will only be a problem if you run Koralias as wavemakers on port 5 or 6.
Posted: Sun Aug 14, 2016 11:31 pm
by Meshmez
I have run them in the past and would like the option to in the future. what will happen if i do? sounds like i should probably send it in...
Posted: Mon Aug 15, 2016 9:13 am
Your controller may reboot once in a while when you are running a rapid on/off on those ports. That's why only port 5 and 6 are intended to be used as wavemakers when koralias are used. Only those ports have the dampening circuit.
