Multiple issues with portal
Related to the Portal
astralmind
Post by astralmind »
Well this is really puzzling me.
The android app works perfectly fine, most of the time (some random timeout) but the portal behaves in a really weird way.
I'm using the DDNS although I have a static IP, port forwarding done right and regardless, the issue happens at home within the LAN.
Using either MS Edge or Chrome, I have the same problem.
basic simple code portion:
ReefAngel.Portal( "astralmind" );
ReefAngel.DDNS( "reef" ); // Your DDNS is astralmind-reef.myreefangel.com
Using the address with : 2000 in my profile to connect.
I don't have a key setup in the portal ie, no password or credentials entered anywhere.
The issue:
When I first connect I get brief (1 second) flash with the current date and time and then it reverts to 6/21/2016 6:32 PM and freezes there for a couple of minutes.
Eventually, it will refresh to the current date and time however, the web banner is permanantly frozen on that time and date. As well, the Relay Activity is always showing "No data" and the Webchart appears blank (on Chrome and Edge).
Moreover, I believe my alerts are still being sent to a previous email address I had entered way back when I was on vacation not to my current email even though it is updated in the portal and saved.
I'm absolutely confused as to what could be causing this.
Any would be greatly appreciated.
astralmind
Re: Multiple issues with portal
Any thoughts, anyone ?
What happens if you remove the DDNS line from your code?
