internal web page no longer working?
Smotz
'Lo - is the internet web portal working?
192.168.0.13:2000/wifi
I add my controller
Then when I click refresh it tells me it is unable to process data..?
Any thoughts?
I add my controller
Any thoughts?
Smotz
Re: internal web page no longer working?
Is there any more support ?
Smotz
I get the error in ra1.jpg no matter if I enter in the public or private IP
Ok, try this.
If you are using the internal Uapp from ipaddress:2000/wifi, please delete the profile and leave it without any profile.
Refresh that page.
You should see an image without any controller shown in the middle top bar. Now, hit refresh.
Does it work?
Refresh that page.
Does it work?
Smotz
Unfortunately, no. Same error.rimai wrote:Ok, try this.
Refresh that page.
Does it work?
Do you have authentication setup for your internal webserver?
Smotz
I do. It authenticates and allows me to the main page.
Smotz
Wont work at all? Any roadmap to make it work?rimai wrote:That's the problem. Uapp will not connect to it
Post an issue on the github to request this.
https://github.com/reefangel/U-App-2.0
If you want to look through the code and help us implement, it would be awesome
The entire UApp is built in HTML5 and javascript.
Smotz
Cool, thx. Will do.rimai wrote:Post an issue on the github to request this.
saf1
So...dumb question. This is the built in portal with the WiFi attachment? Never could get that to work properly so the portal here is what I use.
Smotz
exactly. apparently if you use authentication on the internal web page, it won't work.saf1 wrote:So...dumb question. This is the built in portal with the WiFi attachment? Never could get that to work properly so the portal here is what I use.
