internal web page no longer working?
Posted: Sun Sep 04, 2016 10:21 am
by Smotz
'Lo - is the internet web portal working?
192.168.0.13:2000/wifi
I add my controller
Then when I click refresh it tells me it is unable to process data..?
Any thoughts?
Re: internal web page no longer working?
Posted: Tue Sep 06, 2016 4:57 pm
by Smotz
Is there any more support ?
Posted: Tue Sep 06, 2016 5:06 pm
Can you send screenshot?
Posted: Wed Sep 07, 2016 6:33 am
by Smotz
I get the error in ra1.jpg no matter if I enter in the public or private IP
Posted: Wed Sep 07, 2016 8:17 am
Ok, try this.
If you are using the internal Uapp from ipaddress:2000/wifi, please delete the profile and leave it without any profile.
Refresh that page.
You should see an image without any controller shown in the middle top bar.
Now, hit refresh.
Does it work?
Posted: Wed Sep 07, 2016 10:08 am
by Smotz
rimai wrote:Ok, try this.
Refresh that page.
Now, hit refresh.
Does it work?
Unfortunately, no. Same error.
Posted: Wed Sep 07, 2016 10:43 am
Do you have authentication setup for your internal webserver?
Posted: Wed Sep 07, 2016 11:00 am
by Smotz
I do. It authenticates and allows me to the main page.
Posted: Wed Sep 07, 2016 11:01 am
That's the problem. Uapp will not connect to it
Posted: Wed Sep 07, 2016 11:09 am
by Smotz
rimai wrote:That's the problem. Uapp will not connect to it
Wont work at all? Any roadmap to make it work?
Posted: Wed Sep 07, 2016 11:12 am
Post an issue on the github to request this.
https://github.com/reefangel/U-App-2.0
If you want to look through the code and help us implement, it would be awesome
The entire UApp is built in HTML5 and javascript.
Posted: Wed Sep 07, 2016 11:14 am
by Smotz
rimai wrote:Post an issue on the github to request this.
Cool, thx. Will do.
Posted: Thu Sep 08, 2016 6:50 pm
by saf1
So...dumb question. This is the built in portal with the WiFi attachment? Never could get that to work properly so the portal here is what I use.
Posted: Sun Sep 11, 2016 10:55 am
by Smotz
saf1 wrote:So...dumb question. This is the built in portal with the WiFi attachment? Never could get that to work properly so the portal here is what I use.
exactly. apparently if you use authentication on the internal web page, it won't work.
