ATO Port different use
Posted: Mon Sep 12, 2016 7:32 am
by LucianoB
Hi, I have one simple question. I seemed to understand in some posts.Could I use the RA ATO Ports for one different use? Which? Somebody could give me some light?... I have the Reef Angel Plus Analog, actually I'm using the Relay Box Dimming port (both) for my Kessil.
I don't use that because I have my own ATO system.
Regards!
Re: ATO Port different use
Posted: Mon Sep 12, 2016 8:18 pm
They can be used as 5v pwm ports
Posted: Wed Sep 21, 2016 1:47 pm
by LucianoB
Thank you sir for your answer. Could I use that for plug one RA Jebao Battery Backup? I read, this attachments use one PWM signal. Or what class device use 5v pwm?
Thank you a lot in advance.
lnevo wrote:They can be used as 5v pwm ports
