RA & nano box driver
d0lph1n
Is it possible to control the nano box driver with RA?
http://nano-box-reef.com/blog/?p=42
I'm interested in buying their 13up board.
d0lph1n
Re: RA & nano box driver
The owner says it's not possible and recommends Inventronics drivers instead.
d0lph1n
He says to use a 25w Inventronics.
I think all inventronics accept both Analog or PWM signals.
Just look in the datasheet of the driver and look for the dimming signal.
d0lph1n
I found this one:
http://www.ledgroupbuy.com/inventronics ... ver-700ma/
Wattage: 25W
Max output voltage: 12-36v
Input voltage range: 90 - 305 VAC, 47 to 63 Hz
Input current: 0.48 A @ 110 VAC, 0.23 A @ 220 VAC
Inrush current: 60A at 230VAC 25ºC Cold Start
Dimmable: 0-10v
Dimming range: 10-100%
Spec: EUC-025SxxxDS
LEDs: 4-10 XP/XM CREE LEDs in series at 700mA
Wattage: 25W
Dimmable: 0-10v
Spec: EUC-025SxxxDS
It says they use analog signals.
You can use them. You will also need the PWM-to-Analog lead wire.
d0lph1n
StuGotz
I ordered my LEDs from Dave. I used EUC -025S070DS - EUC Series 25 W 0.7 A 36 V Dimmable Outdoor Constant Current LED Driver.
d0lph1n
I ordered 2 x boards. One for refugium (board2) and one for the main tank (board1), both 12 inch cubes.
I'm planning to run the boards with the same pair of drivers , a pair of relays and RA for dimming:
Daytime
driver1 + relay1 (off): board1 - blue ch
driver2 + relay2 (off):: board1 - white ch
Dusk
driver2 + relay2 (on): board2 - blue ch
Night
driver 1 + relay1 (on): board2 - white ch
driver 2 + relay2 (on): board2 - blue ch
Dawn
Each mode will have different dimming stages.
For runnign 2 boards, Dave suggested a 2 x 40w driver, one fore bleu ch. (board1+2) and one for white ch. (board1+2) but I'm not sure I need that much power since I'll never run both boards (white&blue ch) in the same time. What do you guys suggest?
Daytime
Dusk
Night
Dawn
d0lph1n
I ordered 2 x 25w EUC -025S070DS from futurelightingsolutions.
I'll order the PWM-to-Analog lead wire from roberto.
