Salinity Showing 5.9
Posted: Wed Nov 30, 2016 5:05 pm
I've had problems with the stability of my salinity probe since I first received it. I tried moving it to more temperature stable parts of the sump, and I tried to remove any possible air bubbles.
However, now it only registers a salinity of 5.9, which I believe is indicative of an error. If I try to calibrate it, I only see 0.
Is there any way to determine if this is an issue with the probe or the module?
-Steve
-Steve
