Steve's LED's and Standard PWM RA
Posted: Fri Dec 02, 2016 7:44 pm
by robmwpropane
I have a "Steve's LED" kit that I put together a while ago. It has 4 drivers (each has 3 arrays of 7) and a total of 84 LED's. I was planning on connecting the drivers to the dimming ports on the RA.
Is this ok? The manual doesn't state any limit, but I want to be on the safe side...
Re: PWM Standard RA
Posted: Fri Dec 02, 2016 7:47 pm
I've heard of people that have done it.
I think the signal is PWM.
Re: PWM Standard RA
Posted: Fri Dec 02, 2016 8:05 pm
by robmwpropane
I'm not so sure...I think Steve's are 0-5v PWM
As per this post; http://forum.reefangel.com/viewtopic.ph ... s+per+port
the RA is 0-10V?
Damn...?
Edit: This is on Steve's Website:
-Aquarium controller compatibility - YES! Any aquarium controller with 0-10V dimming can control this driver using Steve's Aquarium Controller Harness. For this driver to accept a 0-10V input, Steve's Aquarium Controller Harness is required.
Double Damn.....
Re: Steve's LED's and Standard PWM RA
Posted: Fri Dec 02, 2016 10:48 pm
The RA can be all those different settings. The ability will depend on how old your relay box is. You have other options too.
Posted: Sat Dec 03, 2016 5:07 am
by robmwpropane
lnevo wrote:The RA can be all those different settings. The ability will depend on how old your relay box is. You have other options too.
It's 2-3 weeks old. Still has that new electronic smell! How can I change it?
Posted: Sat Dec 03, 2016 9:28 am
You can add the dimming expansion module.
It allows you to configure the signal to either 0-5V or 0-10V. You can also choose PWM or analog.
So you have all 4 options to choose.
The relay box is fixed at 0-10V and comes assigned PWM or analog when you purchase it.
Posted: Sat Dec 03, 2016 10:35 am
by robmwpropane
rimai wrote:You can add the dimming expansion module.
Yes, I know about the dimming module, I did not know the RA was 0-10v. To be honest, I didn't know there was 0-5v or 0-10v. I thought there was only analog or PWM.
Is there any other option besides the dimming module? Some sort of programming to limit it to 0-5v, or using an ATO port? My question might be silly, but I honestly don't know...
Posted: Sat Dec 03, 2016 10:55 am
Yes, the ATO ports can be used as 0-5V PWM.
Posted: Sat Dec 03, 2016 12:09 pm
by robmwpropane
rimai wrote:Yes, the ATO ports can be used as 0-5V PWM.
I hate to ask, but I can't find a link anywhere? Any pointers?
Posted: Sat Dec 03, 2016 1:03 pm
Read this:
http://forum.reefangel.com/viewtopic.ph ... 49&p=51008
Basically you need to add a code like this:
pinMode(lowATOPin,OUTPUT);
analogWrite(lowATOPin,PWMSlope(8,0,18,0,5,50,60,5));
pinMode(highATOPin,OUTPUT);
analogWrite(highATOPin,PWMSlope(8,0,18,0,5,50,60,5));
Posted: Sat Dec 03, 2016 4:16 pm
by robmwpropane
rimai wrote:Read this:
Awsome!, Thanks, will give it a read this weekend...
Posted: Thu Dec 08, 2016 9:18 pm
by robmwpropane
Just wanted to add to this thread, I did confirm Steve's drivers are 0-5v PWM for anybody who's looking for info.
Posted: Mon Jan 02, 2017 9:10 am
by robmwpropane
Just following up, I bought the 6 channel dimmer module and got everything connected over the weekend. Works perfect, I did it this way because I wanted control of of all 4 channels and hence color.
