Moving the control wire to the dimmer module
Taking the A1 controller out and using the stock controller
Moving the electric wire
Running an extension cord from a completely different circuit across the room
No matter what I do, eventually it causes a bus lock. Could the pump itself be too close to something? I have it in the same section of the sump as the temp sensor, ph probe, and 2-300watt heaters. The RA is about 12" from the pump on the other side of a wall.
Do DC pumps put out some kind of electro magnetic field or something (if that sounds silly, it's because I'm not an electrician, lol)
I'm at a loss, sure could use some help to figure this out????
